Voltage Low? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 12:19 PM   #1
Rewards Points: 518
Voltage low?
I'm looking at purchasing a condo and I metered a few outlets throughout the suite. Voltage shows between 113-115V. This is lower than what I'm normally used to seeing in a house and I'm wondering if this is going to be an issue.
n0c7 is offline   Reply With Quote
Old 01-18-2010, 01:03 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 958
Should not be a problem.
Have you checked the batteries in the meter?
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 01-18-2010, 04:43 PM   #3
Rewards Points: 2,800
The normal voltage range is 110 to 120.
105 is considered abnormally low.
125 is considered abnormally high.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 01-18-2010, 04:57 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
actually, depending on what requirements there are on your power company, the allowed voltage could vary. Here in the states, federally I believe they are required to maintain +/-10% but there are some more localized areas that require +/- 5%.
So, if nominal voltage is 120, +/- 10% would give you a range from 108-132. If the tolerance was 5%, the range would be 114-126
since you are in Canada, I have no idea what your allowed tolerances are but even in the strictest areas of the US, your readings would fall right on the line of ok/too low. I see no problem with that voltage in itself but I would investigate things a bit more if it were my purchase. If nothing else, call the power company and ask them what their tolerances are and what the typical voltage is for the area you are looking at. Those are both bits of info they should be able to provide to you.
Low Voltage Post Light b_corwin Landscaping & Lawn Care 1 10-16-2009 09:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
high voltage fire alarm jungboklee Electrical 3 01-26-2009 09:07 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
Low voltage to vacuum [email protected] Electrical 2 03-04-2007 09:38 AM
