Voltage Drop/box Fill Calc - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2010, 08:15 PM   #1
as seen on tv
Rewards Points: 150
Question
voltage drop/box fill calc
I am planning on running a 120v 20a circuit approximately 300' to an appliance. i used vd calc formula 2xKxLxI/ cm and came up with a drop of 9.4% for #8 wire and will use 3/4 emt with fittings and pull points were necessary. Number #8 sounds large but run the numbers twice to make sure, what do the pros think?
qbert is offline   Reply With Quote
Old 01-23-2010, 08:36 PM   #2
What is the load ?
Old 01-23-2010, 08:38 PM   #3
as seen on tv
Rewards Points: 150
furnace on a 20a single pole recepticle
Old 01-23-2010, 09:51 PM   #4
Master Electrician
richgriffith's Avatar
what does the nameplate on the furnace say for total load in amps?
try these two sites to answer your questions on voltage drop & conduit fill. hope this helps good luck!!
http://www.elec-toolbox.com/calculators/voltdrop.htm
http://www.electrician2.com/calculat...alculator.html
richgriffith is offline   Reply With Quote
Old 01-23-2010, 10:24 PM   #5
as seen on tv
Rewards Points: 150
After looking threw the 08 code book i realize the recommendation of 3% drop which increases the size again making the whole project not such a good plan. Thanks for the responses. I will be exploring other options for a power supply.
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 06:19 AM
