Very Old House That Has 2 Wired Outlets? Please Help! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 12-17-2009, 05:06 PM   #16
Originally Posted by redblotoflife View Post
I did tie the black to brass an white to silver and did many different variations but it did not work.
Is this a new 2 prong outlet or an old one ?
Did the outlet work before ?
Possibly it was disconnected at some point
Scuba_Dave is offline
Old 12-17-2009, 05:14 PM   #17
If you tied the wires on the outlet as you said it should have power when you plug something in it or test it with a meter.
check back down the line something else must be wrong.
SULTINI is offline
Old 12-17-2009, 05:17 PM   #18
okay
where do I buy gfci 3 prong outlets that work with 2 wirings?
sullin: "If you tied the wires on the outlet as you said it should have power when you plug something in it or test it with a meter.
check back down the line something else must be wrong."
The diagram on this 3 prong that I have shows 4 lines so it might be too new and not adequate for the old system. I have to find one that suits a 2 wiring system.
redblotoflife is offline
Old 12-17-2009, 05:30 PM   #19
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
Forget the diagram that came with the outlet. The diagram is showing the in and out wiring. Your problem right now is to find out why there isn't any power. Check to see if any other outlets are not working because this sound like this is at the end of line. If you find outlets that are not working check breaker/fuse panel to see if breaker tripped or fuse had blown. If you solve that problem, you can buy a GFCI outlet at LOwes, Home Depot etc.
HIVOLT is offline
Old 12-17-2009, 05:38 PM   #20
actually
none of the stores you listed has the 2 wiring 3 prong hence far I will have to call or email homedepot I guess.
Old 12-17-2009, 05:43 PM   #21
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
A GFCI is a 3 prong outlet and can be purchased at Lowes, HD or even a hardware store.
HIVOLT is offline
Old 12-17-2009, 05:45 PM   #22
your not getting it
your not getting it it has to have 3 wires the one's I've seen from homedepot NEED 3 wires
I only have 2 wires.
Old 12-17-2009, 05:48 PM   #23
It does NOT need to have 3 wires
A 3 prong WILL have a place to put 3 wires
EVERY 120v outlet ONLY needs HOT & NEUTRAL to work
Old 12-17-2009, 05:50 PM   #24
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
My friend, the reason you have 2 wires (black and white) is because you either have BX or the old romex. The new wire of today comes with 3 wires (black-white and green or bare copper) The black wire goes to the brass screw the white to the silver screw and the green/bare to the green screw for the ground. You gave an ungrounded system this is why you have only 2 wires. If you buy a GFCI you do not use the green screw and use the label that says "no ground present"
HIVOLT is offline
Old 12-17-2009, 05:57 PM   #25
oki doki
well I will try getting this gfci and tell you all how it goes..
I have played around with the wiring alot so I do know when the power is all shut off there is no danger because I have not been electrocuted
no body is getting the fact that most of these gfci's say you need 3 wires for it to work..
also I know enough not to buy a 20 AMP because I do believe it cannot handle that much amperage.
Old 12-17-2009, 05:59 PM   #26
If you connected the 2 wires you have correctly & the outlet did not work then a GFCI will not work either
You need to find out why you do not have power from the 2 wires
Old 12-17-2009, 06:00 PM   #27
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
That is correct...for it to work properly by tripping if there is a ground.
HIVOLT is offline
Old 12-17-2009, 06:02 PM   #28
hmm
scuba dave how do I go about figuring out this other than electrocuting myself ;0?
Old 12-17-2009, 06:11 PM   #29
I use a meter to test the wires for voltage
IF power is off AND YOU ARE SURE...then you can connect a plug to lamp to the wires & see if the lamp works
If no power then you will need to start opening other outlets to see if a wire came loose
Any other outlets not working ?
Why are you replacing the outlet ?
What happened that the old one is no longer working ?
Old 12-17-2009, 06:29 PM   #30
lets just say
the old outlet got ripped out by a jacktard and tossed to the four wind.
in short where can I buy a 3 prong 2 wire gfci outlet ? all the one's I see are 3 wiring.
Closed Thread
Tags
old housing outlets
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 04:05 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
