Verifying Something On GFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 08-20-2009, 05:32 PM   #1
LeviDIY's Avatar
Rewards Points: 252
Post
Verifying something on GFCI
Hey all - just want to verify one thing here... to upgrade a standard branch to GFCI, you just need to replace a standard outlet with a GFCI receptacle and that outlet and any ones further down the line are protected? Is it really that simple? Am I missing something?
LeviDIY is offline   Reply With Quote
Old 08-20-2009, 05:37 PM   #2
Licensed electrician
Rewards Points: 3,740
Almost. If you only wire using the LINE terminals no receptacles downstream will be GFI protected. If you wire one pair of wires going to the downstream receptacles to the LOAD and wire the incoming hot cable to the LINE terminals you will protect the downstream receptacles.
Old 08-20-2009, 05:39 PM   #3
LeviDIY's Avatar
Rewards Points: 252
Wow... I don't know why I thought it was this whole big deal to do... thanks!
Old 08-20-2009, 05:40 PM   #4
OK, on the back of the GFCI there are two points to put your wires into.
The wires from the panel that feed the first recep. go into the holes marked "LINE"
If you wish any recep downstream from this to be protected, they must go in the holes (or screws) marked "LOAD". This is the correct way to connect these.
Apparently, I typed too slow! Jim already answered!!
BCSparkyGirl is offline   Reply With Quote
Tags
gfci , gfci switch/outlet
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
