Using Urd Wire In The Attic? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2010, 05:15 PM   #1
using urd wire in the attic?
I work at a local hardware store and was told by a customer that a local inspector had informed him that it was legel by NEC 2008 code to run #4 urd wire in flex through his attic to a sub panel, also that 3 wire was sufficient. Since I am aware that it state 4 wires past the first point of disconnect leads me to question the first statement . Anyone have an idea where to find this in the code book , to back my suspitions?
groundhawg is offline   Reply With Quote
Old 03-22-2010, 05:48 PM   #2
Sub panel needs 4 wires under NEC 2008
What were they connecting in the sub ?
Was it for a specific use ?
Old 03-22-2010, 05:52 PM   #3
Master Electrician
Rewards Points: 5,084
URD is not a listed wirng method.
brric is online now   Reply With Quote
Old 03-22-2010, 06:04 PM   #4
Rewards Points: 506
What is URD?
jlmran is offline   Reply With Quote
Old 03-22-2010, 06:11 PM   #5
Master Electrician
Underground Residential Distribution
Old 03-23-2010, 12:49 AM   #6
" Euro " electrician
frenchelectrican's Avatar
If I remember right the URD is the same as XPLE and it is not used in the building at all due it do not have flame restanine rating at all.
Second thing I do not know why the inspector say it is ok to use 3 conductor set up instead of 4 conductor set up per NEC code and due this is in a common building { not going to detached building ATM } and it MUST be in 4 conductors I know in Wisconsin do not allow 3 conductors for subfeed anymore.
In France it almost parallel with NEC but few changes with it.
Merci,Marc
running wire with no attic space? drshonts Electrical 9 01-15-2016 11:14 AM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 08:55 AM
How do I wire these switches? keano016 Electrical 2 10-07-2009 10:19 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
