Using A Dc Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2010, 10:07 AM   #1
using a dc fan
How do you hook up a dc 40 cfm fan to ac current. Do they make a fan with this connection? I want to make a unit to move hot air from the ceiling to the floor thru a box in the corner of the rooms. Ac fans are too big and costly.
wtaylor is offline   Reply With Quote
Old 02-18-2010, 10:45 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
well, you need a power inverter to change the AC voltage to DC of the proper voltage needed.
what is the voltage rating of the fan?
and how large of fan (physically) is this?
is it round or square and does that really make a difference to you?
Old 02-18-2010, 01:14 PM   #3
Originally Posted by nap View Post
well, you need a power inverter to change the ac voltage to dc of the proper voltage needed.
What is the voltage rating of the fan? 5.5 volts
and how large of fan (physically) is this? 3" x 3" square
it's a zalman model zm-f1 plus fan
Old 02-18-2010, 01:33 PM   #4
nap
You talking to me?
nap's Avatar
You could use something such as this:
http://www.allelectronics.com/make-a...GULATED/1.html
Not sure of the power requirements of the fan. You might have to source a larger capacity (MA rating).
does your fan have a watt or amp rating on it?
Old 02-18-2010, 01:59 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,494
Ayuh,... There's fans, pretty much Exactly like that 1 which run on 120v AC....
It'll be cheaper to buy the Right fan, than buying something to convert to 12v...
I know these guys have 'em,... Cheap...
Bondo is online now   Reply With Quote
Old 02-18-2010, 02:07 PM   #6
nap
You talking to me?
nap's Avatar
sure enough. I took a quick look and they have several I saw that would seem to fit the bill and you do not have to buy the power supply.
Old 02-18-2010, 02:50 PM   #7
Yes they seem to have what I'm looking for. I sent for there catalog.
Shipping is very pricey though.
Thanks for your help
Old 02-18-2010, 04:08 PM   #8
Rewards Points: 308
All you need is a small cheap rectifier cube like this pictured below. Estimated cost $4.00. I'm guessing. AC in DC out.
This one is rated for 35 amps. You will not need 35 amps.
Old 02-18-2010, 06:36 PM   #9
nap
You talking to me?
nap's Avatar
Um, JV,
what about the voltage?
the fan he asked about is 5.5 VDC. You would get a bit more than that if that rectifier is all you put in the line.
Old 02-18-2010, 09:12 PM   #10
as seen on tv
Rewards Points: 150
step down xmfer an 4 diodes
qbert is offline   Reply With Quote
