Using 3 X 110V 15A Extension Cords For 250V 50A Outlet - Electrical - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 2 Post By dmxtothemax
  • 1 Post By trialanderror
  • 1 Post By lenaitch
  • 1 Post By circuitman
  • 1 Post By FrodoOne
Old 11-13-2017, 11:17 PM   #1
Using 3 x 110V 15A extension cords for 250V 50A outlet
I was trying to find a 50-100 foot extension cord for a NEMA 10-30P 50AMP (Dryer) outlet with no luck, plus I am sure they are several hundred dollars for that length. I need to power a few computers that are running at 1400W and accept 110V-240V on the power supply.
My first thought is to get this adapter =
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
to convert it to a standard NEMA 5-15P outlet. Then add one of these =
https://www.homedepot.com/p/GE-3-Out...4541/203742102
Followed by 3 x 100 foot 12 gauge 15AMP extension cords:
https://www.homedepot.com/p/Husky-10...0H31/205377755
Then plug in one computer at the end of each extension cord.
I am thinking that logically this would work since the current is distributed throughout the 3 cords however the grounded 3 outlet splitter is only rated for 15AMP's and would be taking a 45 AMP load so I may need to find a better splitter. Anyone know any options?
Let me know if you guys think this would work providing I get a better splitter or if another solution would be more practical, purhaps buying a NEMA 10-30P plug instead and building an extension cord but would still need a way to split it into 3.
Also would the 250V cause issues going into the 110-240V computer power supply?
trialanderror is offline   Reply With Quote
Old 11-14-2017, 01:08 AM   #2
dmxtothemax's Avatar
Rewards Points: 7,850
Re: Using 3 x 110V 15A extension cords for 250V 50A outlet
Problem = "Combined load must be less than 15 amps or 1875 watts "
And you want three times that ?
Said adaptor will never carry the load !
Bondo and joecaption like this.
dmxtothemax is offline   Reply With Quote
Old 11-14-2017, 01:20 AM   #3
Rewards Points: 3,008
I would hope that a "normal" 5-15 plug (or adapter) would NOT fit (could not be made to fit) into a 14-50 socket, since a device expecting 120 V might then be connected to 240 V ! !
If it does fit, your proposed set-up would have no Ground on the Ground Pin, since the 10-30 socket supplies a Neutral but no Ground.
Originally Posted by trialanderror View Post
would the 250V (sic) cause issues going into the 110-240V computer power supply?
YES, if the power supply were switched to 110 V
NO, if the power supply were switched to 240 V
the grounded (?) 3 outlet splitter is only rated for 15AMP's and would be taking a 45 AMP load so I may need to find a better splitter
Three 1400 W devices on 240 V would draw 17.5 A max.
FrodoOne is offline   Reply With Quote
Old 11-14-2017, 05:09 AM   #4
Ever Learning
Blue Marjan's Avatar
Rewards Points: 316
I have built custom extension cords - always remember that the devil is in the details!!
http://www.cmewire.com/catalog/sec19...-cu-01-amp.pdf
shop for your wire carefully ...
https://www.homedepot.com/b/Electric...vZbm7vZ1z0zudd
make sure EVERY component can handle the amperage
using a Dryer plug for suitable current ratings works
are there code problems building a box at the end of your custom cord which holds suitable outlets? rather than using an off-the-shelf splitter? electrically you can build a box fed by the cord which holds 3 suitable outlets, I'm just not sure what the code issues might be. I have a specific inspector I call here with that sort of question.
Blue Marjan is offline   Reply With Quote
Old 11-14-2017, 08:18 AM   #5
Licensed electrician
Rewards Points: 3,832
Regular receptacles are limited to 20 amps maximum . You cannot feed them from a 50 amp circuit.
Old 11-14-2017, 10:09 AM   #6
Thank you everyone. Looks like it may make more sense to hire an electrician to just to rewire it for 110V at the panel. The computers will be closer to the panel anyways
lenaitch likes this.
Old 11-14-2017, 12:27 PM   #7
Rewards Points: 4,794
I think hiring this done would be good for two reasons:
1. Extension cords are not meant for permanent use
2. Nominal voltage in the US has been 120 volts and not 110 for a long enough time that anyone who says/writes 110 leads me to believe they have little experience with electrical work
stick\shift is offline   Reply With Quote
Old 11-14-2017, 03:30 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 2,016
I came to this thread after the OP wisely realized that a professional was in order. If there were extra reward points for the most dangerous idea of the year, this might have been the winner.
kerryman71 likes this.
lenaitch is offline   Reply With Quote
Old 11-14-2017, 08:36 PM   #9
Rewards Points: 558
maybe the darwin award of the year?
circuitman is offline   Reply With Quote
Old 11-15-2017, 12:56 AM   #10
Surely http://www.diychatroom.com/f18/fun-project-help-563658/ must be in the running!
Old 11-15-2017, 02:06 AM   #11
Ever Learning
Rewards Points: 316
(red face)
looks like I mis-read the original post. This sounds like sub-panel time.
Extension cords. If 14 gauge can supply 15A Sliding Man Electrical 12 12-04-2018 09:39 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Does the 80% of peak rule apply to extension cords? Delta223 Electrical 23 02-21-2010 01:09 PM
Extension Cords Types alnoir Electrical 17 10-21-2009 05:37 PM
