Use The Junction Box In A Can Light To Pass Through Another Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-06-2012, 11:15 AM   #1
j_sun's Avatar
Use the junction box in a can light to pass through another circuit
Hi All,
I am in the process of putting a new drywall ceiling in my kitchen along with new can lights. While I've had the old ceiling out, I've taken the opportunity to remove all the old knt wiring that I can.
Currently my balcony, which is above the kitchen, has all the new proper wiring dropped down for the receptacles in the room. Problem is that it goes into a junction box where it is tied into the old knt feed circuit. I plan to run a new feed wire up from the basement to replace the knt. I really don't want to have a jb with a cover poking through my ceiling if I don't have to.
My question is can I run the 2x 12/2 wires to the receptacles and the new 12/2 feed wire into one of the junction boxes of a can light to make the connections? They will be on separate breakers.
I am installing Halo H7ICT 6" fixtures. (I can't seem to find the volume of their junction boxes anywhere)
So in the box I will have the following:
3x 12/2 roamex (passthrough to outlets above)
2x 14/2 roamex (feed and out for other cans)
and the fixture pigtail of course
Will this work?
(FYI that it would almost be impossible to make a home run from the panel to the balcony outlets. I dropped the new wiring down when I had my bathroom tore apart a few years back but now have no easy access to that wall cavity.)
Thanks,
Jason
j_sun is offline   Reply With Quote
Old 09-06-2012, 12:36 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,444
Normally it is no problem to have conductors from different circuits in the same junction box however I don't think the junction box on the can light will be large enough to fit all those cables.
The Following User Says Thank You to joed For This Useful Post:
j_sun (09-06-2012)
Old 09-06-2012, 12:43 PM   #3
j_sun's Avatar
Originally Posted by joed View Post
....... I don't think the junction box on the can light will be large enough to fit all those cables.
Hi Joed,
As I'm still new to this, can you verify that I would use the following to calculate the box volume requirements for 3x 12/2 + 2x 14/2 + 16g fixture:
6x 12awg wires = 13.5
4x 14 awg wires = 8.0
1x 12 awg ground = 2.25
2x 16 awg fixture wires = 3.5
total volume = 27.25 cu in
Make sense?
Old 09-06-2012, 01:53 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 588
I would use a junction box for the wiring to the receptacles and place that JB immediately above one of the can lights. Install a retrofit (instead of a new work) can in that location that can be removed to access the JB.
Let the beatings begin.
I say this meets the accessibility requirement.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 09-06-2012, 10:47 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Of course it does, i've installed j-boxes behind fixed microwaves, is it a *****, sure is... but it is accessible.
Old 09-07-2012, 06:42 AM   #6
Resi EC
Rewards Points: 252
Originally Posted by j_sun View Post
Hi Joed,
Make sense?
Now you can figure the cu in of the junction box on the recessed light.
H x W x D (height, width, depth) = cu in
But, I agree it may not be large enough for your needs.
rjniles option will probably be your best bet, I don't believe it would need to be a re-mod can, as new construction cans housings can be removed to access the J box also
Gac66610 is offline   Reply With Quote
Old 09-07-2012, 09:07 AM   #7
Licensed electrician
Rewards Points: 3,608
The junction box for the recess will have the number of cables allowed stamped on it. They are not sized the same as device boxes.
Old 09-07-2012, 02:12 PM   #8
Super Moderator
joed's Avatar
I don't think you count the #16 fixture wires.
Most can light boxes are just big enough for two cables.
Old 09-07-2012, 02:47 PM   #9
Sparky
Rewards Points: 510
Most i see are rated for 8 #12's, if memory serves, haven't put up too many can lights recently
Techy is offline   Reply With Quote
Installing Light on Round Junction Service Box MegR Electrical 7 07-07-2013 08:31 PM
Circuit Breaker Tripping when I turn on kitchen light fixture hiker23 Electrical 2 02-04-2012 02:30 PM
Arc fault light briefly lit when turning circuit back on... darthsmozers Electrical 26 01-16-2012 10:04 AM
Bathroom light on a gfi circuit Debbo Electrical 1 04-28-2010 09:32 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
