DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Use the junction box in a can light to pass through another circuit (https://www.diychatroom.com/f18/use-junction-box-can-light-pass-through-another-circuit-156023/)
j_sun 09-06-2012 12:15 PM
Hi All,
I am in the process of putting a new drywall ceiling in my kitchen along with new can lights. While I've had the old ceiling out, I've taken the opportunity to remove all the old knt wiring that I can.
Currently my balcony, which is above the kitchen, has all the new proper wiring dropped down for the receptacles in the room. Problem is that it goes into a junction box where it is tied into the old knt feed circuit. I plan to run a new feed wire up from the basement to replace the knt. I really don't want to have a jb with a cover poking through my ceiling if I don't have to.
My question is can I run the 2x 12/2 wires to the receptacles and the new 12/2 feed wire into one of the junction boxes of a can light to make the connections? They will be on separate breakers.
I am installing Halo H7ICT 6" fixtures. (I can't seem to find the volume of their junction boxes anywhere)
So in the box I will have the following:
3x 12/2 roamex (passthrough to outlets above)
2x 14/2 roamex (feed and out for other cans)
and the fixture pigtail of course
Will this work?
(FYI that it would almost be impossible to make a home run from the panel to the balcony outlets. I dropped the new wiring down when I had my bathroom tore apart a few years back but now have no easy access to that wall cavity.)
Thanks,
Jason
joed 09-06-2012 01:36 PM
Normally it is no problem to have conductors from different circuits in the same junction box however I don't think the junction box on the can light will be large enough to fit all those cables.
j_sun 09-06-2012 01:43 PM
Originally Posted by joed (Post 1004414)
....... I don't think the junction box on the can light will be large enough to fit all those cables.
Hi Joed,
As I'm still new to this, can you verify that I would use the following to calculate the box volume requirements for 3x 12/2 + 2x 14/2 + 16g fixture:
6x 12awg wires = 13.5
4x 14 awg wires = 8.0
1x 12 awg ground = 2.25
2x 16 awg fixture wires = 3.5
total volume = 27.25 cu in
Make sense?
rjniles 09-06-2012 02:53 PM
I would use a junction box for the wiring to the receptacles and place that JB immediately above one of the can lights. Install a retrofit (instead of a new work) can in that location that can be removed to access the JB.
Let the beatings begin.:yes:
I say this meets the accessibility requirement.
stickboy1375 09-06-2012 11:47 PM
12 Attachment(s)
Of course it does, i've installed j-boxes behind fixed microwaves, is it a *****, sure is... but it is accessible. :)
Gac66610 09-07-2012 07:42 AM
Originally Posted by j_sun (Post 1004421)
Hi Joed,
Make sense?
Now you can figure the cu in of the junction box on the recessed light.
H x W x D (height, width, depth) = cu in
But, I agree it may not be large enough for your needs.
rjniles option will probably be your best bet, I don't believe it would need to be a re-mod can, as new construction cans housings can be removed to access the J box also
Jim Port 09-07-2012 10:07 AM
The junction box for the recess will have the number of cables allowed stamped on it. They are not sized the same as device boxes.
joed 09-07-2012 03:12 PM
I don't think you count the #16 fixture wires.
Most can light boxes are just big enough for two cables.
Techy 09-07-2012 03:47 PM
Most i see are rated for 8 #12's, if memory serves, haven't put up too many can lights recently
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
