Use Of AFCI Devices - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 10:44 PM   #1
Use of AFCI devices
I recently build a house, and I installed 16 AFCI ckt breakers.
After about 6 months, at 6AM in the morning, something happened such that 8 of the AFCIs tripped. In addition, all 8 were permanently destroyed and had to be replaced at $40 each. The other 8 AFCIs were not tripped or degraded, as well as all of the standard breakers and GFCIs in the breaker panel. We found out that there was a loose connection in the breaker box out on the light pole next to meter.
Apparently the AFCIs are not as durable as standard circuit breakers or GFCI.
Is this a known problem(ie, not durable and multiple failures at once), or was this a bad batch of parts?
Any ideas?????
voltin is offline   Reply With Quote
Old 12-29-2009, 04:46 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If the loose connection was on the neutral, it could have sent an over voltage through the breaker and fried the power supply/electronics in the breaker.
GFCI breakers contain a current transformer so, it could possibly handle a possible over voltage condition.
Sounds like those breakers were on the same leg that received the over voltage. IMO, it wasn't defective breakers.
wirenut1110 is offline   Reply With Quote
Old 12-29-2009, 06:02 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Ditto on Wirenut,
Unlike thermal-magnetic breakers, AFCI's contain IC's which like all IC''s don't tolerate abnormal conditions very well.
To see an AFCI block diagram scroll down to figure 5:
http://www.iaei.org/magazine/?p=3966
Disclaimer
& Stay Safe
.....Bob Lavery
Old 12-29-2009, 08:57 PM   #4
You might want to report this to the manufacturer here...
http://www.afcisafety.org/report.html
Billy_Bob is offline   Reply With Quote
AFCI trip when computer turns on tonydiato Electrical 61 09-13-2010 06:24 PM
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 11:22 AM
UPS & PC combo trip AFCI Keith Wheeler Electrical 12 12-10-2009 07:04 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 07:21 PM
