Use-2 Wire Inside Exposed - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 07:42 PM   #1
use-2 wire inside exposed
I've searched for hours and get confusing information.
Can I run cable thats marked USE-2 RHH RHW-2 XLPE inside along the joists "not in conduit" to my main panel to a sub panel in another building.
Is this open air?
Cable is #4 copper
Brian
blorentzen is offline   Reply With Quote
Old 09-23-2010, 08:29 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Is this open air?
Cable is #4 copper
Brian
Let me post the photo so you can point which one it is refering
First one is SEU
Or
SER
And the other thing any subpanel runs it must use 4 conductor cable you can not use 3 conductor cable anymore per NEC code.
The other thing the 25mm{#4 AWG } Copper verison you are only limited to 70 amp breaker size max if you go with alum it will drop down to 60 amp max.
is other building is attached or detached if detached you must sink two ground rods as well.
Merci.
Marc
Old 09-23-2010, 08:49 PM   #3
Master Electrician
Rewards Points: 5,082
http://www.iaei.org/magazine/?p=961
No you cannot.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
frenchelectrican (09-23-2010)
Old 09-23-2010, 10:46 PM   #4
The bold statement near the bottom in this spec throws me.
"and may be installed in air"
What does that mean?
Specification
USE-2 or RHW-2 or RHH
XLPE Insulation, 600 Volts
1. SCOPE
1.1 This specification describes single conductor XLPE, Type USE-2 or RHW-2 or RHH, crosslinked polyethylene insulated cables for use in circuits not exceeding 600 volts. Cables are listed by UL as Type USE-2 and are recognized for underground use in wet locations at a maximum continuous conductor temperature of 90C in accordance with Article 338 of the National Electrical Code. The cables are also listed by UL as Type RHH or RHW-2 for general purpose wiring applications at maximum continuous conductor temperature of 90C in dry locations (RHH) or 90C in wet or dry locations (RHW-2) and may be installed in air, conduit or other recognized raceways in accordance with Article 310 of the National Electrical Code.
This spec also confuses me:
http://www.usawire-cable.com/pdfs/USE-2_XLP.pdf
Below it states residential, and dry locations, more confusion.
RHH, RHW-2 and USE-2
UL Types RHH, RHW-2 and USE-2 building wires are also used in residential and commercial buildings, industrial plants, utility substations and generating plants for general-purpose, control, power and switchboard wiring. In most cases, these three types
are combined into one cable (one part number) having all three ratings. In this case, the wire is known as an RHH/RHW-2/USE-2 listed wire or cable. This “triple listed” wire can be installed in conduit or other raceways in either 90C wet or 90C dry locations. Sizes 1/0 AWG and larger are suitable for use in cable trays when identified with the optional UL marking “For CT Use”. Because of the USE-2 listing, it can also be directly buried.
http://www.anixter.com/AXECOM/AXEDoc...g_Wire_B-3.pdf
Old 09-24-2010, 05:26 AM   #5
Master Electrician
You may be correct. I may not have read the entire spec sheet. I would have to investigate further but it may be allowed for your application.
Old 09-24-2010, 06:49 AM   #6
Thanks Merci for the pics but it's neither. These are single cables.
A building electrican just walked by my desk where I work and I asked him. He said I can't run this cable inside.
He said to run #2 alum xhhw in conduit all the way for 100 amp. From the panel underground to the subpanel.
Old 09-24-2010, 07:48 AM   #7
Super Moderator
joed's Avatar
Rewards Points: 24,000
No you can't use individual wires without conduit.
Old 09-24-2010, 08:07 AM   #8
Joed,
Your statement makes me more confused. What is conduit for if not for individual wires?
XHHW: Understanding XHHW Wire
The initials, or acronym, for XHHW stand for Cross-Linked High Heat Water Resistant Insulated Wire. This XHHW is the designation for a specific insulating material for electrical building wire and cable. The term XHHW also designates the temperature rating as well as the conditions that the cable can be used under.
XHHW insulated wires are generally used in residential, commercial and industrial buildings and installations for the purpose of power distribution. The cable is manufactured in both copper and aluminum conductors and typically ran in conduit or other approved raceways for services, feeder and circuit wiring. XHHW insulation is rated by the Underwriters Laboratories (UL) to be suitable for use in dry locations up to 90 degrees Celsius, or wet locations up to 75 degrees Celsius. However, there is a newer and much more popular insulation version of XHHW with the designation of XHHW-2. This allows the insulation to be suitable for use in both wet and dry locations up to 90 degrees Celsius.
Old 09-24-2010, 09:28 AM   #9
I=E/R
a7ecorsair's Avatar
Joed,
Maybe joed missed a semi colon
No you can't use individual wires with conduit.
No you can't; use individual wires with conduit.
a7ecorsair is offline   Reply With Quote
Old 09-24-2010, 12:55 PM   #10
Super Moderator
joed's Avatar
Post corrected. I should have proof read it better.
Old 09-25-2010, 12:02 AM   #11
I make that part bold that mean you have to run the whole thing in conduit and no you can not run indivual conductor without conduit so it is clear on this one.
Merci.
Marc
replacing wire inside ac unit kevinv HVAC 2 07-30-2010 05:27 AM
How do I wire these switches? keano016 Electrical 2 10-07-2009 10:19 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
What is the best way to wire this? RST Electrical 8 08-18-2009 11:29 PM
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 01:15 PM
