Upsizing Copper Wire For 60Amp - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2010, 11:11 PM   #1
Question
Upsizing Copper Wire for 60Amp
Should i spend the $ upfront to upsize from 6/3 with 10 ground to 4/3 with 8 ground. This is for a dedicated service to a 48Amp Spa that requires 60 Amp breaker. Total run of wire is ~75 feet.
skleinsmith is offline   Reply With Quote
Old 04-01-2010, 12:18 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Naw ., not really due you are near the borderline with distance and you can stay with 16mm˛ { # 6 AWG }
However there is one good head up you can not run UF or NM to the spa at all you have to run this in the conduit and use green ground conductor { this is very specfic in NEC code }
Merci,Marc
Old 04-01-2010, 07:37 AM   #3
Licensed electrician
Rewards Points: 3,654
I am going to add one thing to Marc's post. NM can be used on the interior portion of the circuit if the hot tub is installed outside.
Old 04-01-2010, 01:20 PM   #4
Master Electrician
stupid question probably but even us guys with licenses don't know it all and any that say they do....well don't hire them . In this case would it be legal to run a nm cable suitable for direct burial with an insulated ground in it to the hot tub? sleeving the above ground parts in pvc?
andrew79 is offline   Reply With Quote
Old 04-01-2010, 01:28 PM   #5
Master Electrician
Rewards Points: 5,082
That's debatable. Some will argue that the equipment ground of UF cable is insulated by the pvc sheathing. I disagree but I'm absolutely sure a lot of spas are wired that way.
brric is offline   Reply With Quote
Old 04-01-2010, 01:33 PM   #6
Master Electrician
i'm talking of a four wire cable....i've seen them and they aren't cheap so it's probably not cost effective but i was just curious. It's an NMWU cable with an insulated red black white as well as an insulated green.
edit* nevermind we're talking about the same cable i think
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 01:15 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
Wiring of bare copper wire in a light fixture Fleet_Foxes Electrical 5 07-16-2009 08:44 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 02:37 PM
