Upgrading Existing Panel By Changing Main. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-24-2014, 09:23 AM   #16
Rewards Points: 60
The panel and I are in two different locations at the moment . Perhaps your search engine will have better luck getting it's specs by entering the model # (G2030M61150) then I'm having.
nolife is offline   Reply With Quote
Old 10-24-2014, 10:00 AM   #17
Rewards Points: 60
Took a closer look at the pic on my phone and discovered the "6" in that number should be a "B".
Old 10-24-2014, 01:21 PM   #18
Master Electrician
Rewards Points: 5,140
G2030MB1150 is a 20 space/30 circuit, single phase, 150 amp main breaker panel.
brric is online now   Reply With Quote
Old 10-24-2014, 01:40 PM   #19
Rewards Points: 60
http://www.kirbyrisk.com/woeb/datash...70_176_194.pdf This pdf file I found seems to say in the general info page that the EQ load center's Aluminum main lugs are rated 100-225 amperes. Am I reading this right?
Can't believe this was a 600$ load center!
Old 10-24-2014, 02:29 PM   #20
Abcanfield's Avatar
Rewards Points: 12
Looking at the PDF your posting gives a category heading that list specs for 100 amp to 225 amp panels. I don't see where it specifies that all busses are rated up to 225 amps. Am I looking at this wrong?
Abcanfield is offline   Reply With Quote
Old 10-24-2014, 03:02 PM   #21
Rewards Points: 3,396
If everything doesn't work out as your hoping it could be more than that.
It was probably about 200.
For 200 bucks replace the panel.
The other breaker alone is like 180
That's it.
Good luck
ritelec is offline   Reply With Quote
Old 10-24-2014, 04:01 PM   #22
Just wanted to clarify.
This is the breaker style I replaced.
The bottom bolts on the bars. The top has 2 jaws per phase that gets a post plugged into that gets a lug around it that gets the wire...
Also sending a link for multiple main breakers...
Old 10-24-2014, 04:02 PM   #23
http://w3.usa.siemens.com/powerdistr...01-038-039.pdf
Old 10-24-2014, 06:11 PM   #24
Rewards Points: 60
Originally Posted by ritelec View Post
That's what I'm looking at! But older posts have me wondering is it the Gould main breakers that are bad, or the Siemens panel as whole?
Old 10-24-2014, 09:25 PM   #25
Rewards Points: 1,832
My honest opinion is replace the panel. $600 bucks is a rip off for a load center. The model you have appears to be obsolete so its not entirely certain what will work.
Jump-start is offline   Reply With Quote
The Following User Says Thank You to Jump-start For This Useful Post:
ritelec (10-24-2014)
power new 200amp panel as temporary subpanel from existing 100amp main panel CapeCod153 Electrical 4 03-21-2013 09:31 PM
Main Breaker in a Main Lug panel? fulmar2 Electrical 17 01-30-2013 12:16 PM
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
changing main panel rustic Electrical 10 01-05-2009 10:35 AM
