Upgrading To 200 Amp Service - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 03:54 PM   #1
Upgrading to 200 Amp Service
I've never actually done this, so I want to make sure I have all my bases covered. I know that I need to have the power company come out and pull the meter, and install a new one once the new panel is in place and hooked up. The wiring from the meter to the box would also have to be upgraded, right? There's probably only six feet of wire from the meter to the box. What gauge do I need to use?
CoreyK is offline   Reply With Quote
Old 11-29-2010, 04:10 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 702
First you will need a permit. Are you allowed to do this work in your locality? You will probably need a new meter socket and mast/wiring up to the weather head. New wiring from the meter to the main panel and probably a new main panel. Based on your question are, you sure this something you can and should do yourself?
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 11-29-2010, 04:48 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Also larger cable from the meter to the pole.
Call the power company and get all their requirements including for permits.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-29-2010, 05:45 PM   #4
I would def say unless ur an electrician, do not do this on ur own. Ur asking for major headaches....
heartlessmcfly is offline   Reply With Quote
Old 11-29-2010, 09:16 PM   #5
Rewards Points: 150
The first one of these I did, I had just as many questions, so they aren't automatically a "this will fail" flag. I did as much research as I could on my own, however, so I sounded like I knew a little more when I came to the forums (not this forum, mind you, as I hadn't seen it yet)
emolatur is offline   Reply With Quote
Old 11-30-2010, 07:15 AM   #6
Like all of these guys are saying... I actually did this same project but mine was a underground service feed so I lucked out with the fact that they had already run cable large enough to deliver 200 amps... But to answer your question about wire size coming from the meterbox to the panel the question is Aluminum or Copper which one do you wanna go with?
joshvette001 is offline   Reply With Quote
Old 11-30-2010, 07:32 AM   #7
1st thing I did was contact the POCO & see if I could upgrade
I was considering 300a service
There are still areas that 200a might be a problem
Also ask them what they install, and what you need to install
2nd contact your Building Dept & see if you are allowed to do the work
Here I was required to have an electrician run the main feed & connect the new meter base & 200 main feed
upgrading service sirsparksalot Electrical 1 10-20-2010 09:29 AM
upgrading to 200 amp service Vikeologist Electrical 10 12-20-2009 06:38 PM
Need opinions on the cost/necessity of upgrading service. Simplemines Electrical 3 10-19-2008 09:41 AM
upgrading service for added garage jakeb Electrical 12 03-29-2008 12:18 PM
upgrading service cable Clutchcargo Electrical 1 06-22-2007 10:04 AM
