Upgrade Fuse Panel To Breaker Panel Myself? Apartment Complex - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By J. V.
Old 06-28-2018, 10:28 AM   #1
Rewards Points: 78
Upgrade fuse panel to breaker panel myself? Apartment complex
Hey all,
So, I just purchased a small, low income, apartment complex in my town. More humble than it sounds. That said, a few units still have small fuse panels. 300sqft units. There are sub meters in an electrical room where I can shut off the power to the unit. I'm not really afraid of the process of swapping it out, moreso the red tape. Just checking that I could legally do this. I live in Washington state. Do I just need to apply for a permit, so the works then get it inspected?
Perhaps you guys could point me in the right direction. I can also post pictures or more info if you guys foresee an issue that I haven't.
Joe
gijoe985 is offline   Reply With Quote
Old 06-28-2018, 10:37 AM   #2
Rewards Points: 2,800
Re: Upgrade fuse panel to breaker panel myself? Apartment complex
Many cities require that electrical work in multifamily and non-owner-occupied and commercial properties be done by a licensed electrician.
Aside from that, it is easier to do since the apartment unit has a master disconnect switch upstream, at the meter box. You don't have to coordinate with the power company.
Be prepared to need to install heavier wiring from the meter box to the unit in case today's code requires more amperes than the apartment now has. In turn a larger service (more amperes) to the whole building might be needed.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 06-28-2018, 10:38 AM   #3
Rewards Points: 308
Call the building dept/code enforcement office and see if its allowed.
I highly doubt they give you a permit for a multi family complex of any sort.
CodeMatters likes this.
If it worked before you worked on it. You did something wrong.
Old 06-28-2018, 03:35 PM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,312
What about the meter bank and main cabinet?
Odds are it's a cobbled together mess just begging for improvement.
Old 06-28-2018, 03:57 PM   #5
Rewards Points: 78
That stuff is new.
Old 06-28-2018, 04:13 PM   #6
MarginallyQualified
That stuff is new.
Find out who did that work and ask them to bid your panels.
They'll already know the job.
(Verify the licensed EC required question with the County if you think you need to but also check what the insurance company requires)
Panel Full, Now What? Thai4 Electrical 12 04-03-2018 03:18 AM
Need advice on breaker panel / breakers Star Trek Texan Electrical 11 02-24-2016 04:20 PM
subpanel main breaker doesn't match main panel breaker mslide Electrical 3 12-30-2014 03:38 PM
outlets in two rooms not working, but still have power? sanjix1 Electrical 54 06-12-2014 06:47 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
