Up Side Down Outlets - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-26-2016, 03:52 PM   #31
Jello Wrangler
Rewards Points: 539
Re: Up side down outlets
Originally Posted by Oso954 View Post
I've heard that one many times, but I don't agree that it's valid. You need two things too happen, a partially inserted plug and the faceplate screw backing all the way out. What's the chances of both of those happening ?
If it did, it was most likely some duffus who tried removing a faceplate while something was still plugged in.
But then it's only a factor if the cord has a ground, most lamp cords, chargers, devices and the like don't.
ChiTownPro is offline   Reply With Quote
Old 04-26-2016, 04:40 PM   #32
dmxtothemax's Avatar
Rewards Points: 7,326
Originally Posted by TheEplumber View Post
Seems the apprentice was right-
Why did you have to say that ?
now they will be insufferable !
dmxtothemax is online now   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Tom738 (04-27-2016)
Old 04-26-2016, 09:29 PM   #33
Rewards Points: 118
This issue seems to be raised here some regularity. I am increasingly convinced that I am the only person that does not routinely store sheet metal directly above all their electrical outlets in some manner just waiting to fall.
Someone needs to make a duplex output where one is ground up and one is ground down. It would be perfect for those that want to switch half an outlet. (I'd buy it just to watch people stare at it.) We'd probably argue over whether the grounds should point towards the center or the outside though.
LanterDan is online now   Reply With Quote
Old 04-26-2016, 09:34 PM   #34
Jello Wrangler
Rewards Points: 539
All of our outlets are installed horizontal. None of this matters around here.
Old 04-26-2016, 10:03 PM   #35
Super Moderator
joed's Avatar
Rewards Points: 22,722
Yes does. Now do you put the ground right or left. That would also be the hot pin up or down.
Old 04-26-2016, 11:17 PM   #36
Jello Wrangler
Rewards Points: 539
No it doesn't. The ground isn't up or down. So we don't have to worry about which way it goes.
But if you are referring to whether the hot or neutral is up, still doesn't matter as the odds of something happening are so microscopic it's a non-issue regardless of horizontal, vertical, up or down. It only matters to those that are OCD.
Being consistent is more important.
The Following 2 Users Say Thank You to ChiTownPro For This Useful Post:
Californiadecks (04-27-2016), Know A Little (04-27-2016)
Old 04-26-2016, 11:43 PM   #37
Originally Posted by chitownpro View Post
all of our outlets are installed horizontal. None of this matters around here.
rebel !
Old 04-27-2016, 04:48 AM   #38
Rewards Points: 2,360
Of course, (virtually) all Australian socket outlets are installed horizontally, with the earth pin down - and they all have inbuilt switches.
http://www.clipsal.com/Trade/Product...ail?catno=2025
They are also available for Vertical installation, and I understand that this is preferred in New Zealand.
http://www.clipsal.com/Trade/Product...il?catno=2025V
This design was "adapted" (pinched!) (in 1937) from a certain US design. (US patent 1,179,728 - 1916) The dimensions, space occupied and the threads of the securing screws are all exactly the same as those for North American outlets.
(While it may look like a NEMA 10-50, the NEMA 10-50 is larger.)
China and Argentina also use this design - but the Chinese use it "upside down".
The International Electrotechnical Commission (IEC) "world plugs" Web site calls this plug Type I.
(The IEC designation for North American plugs is Type A [not-Earthed], and Type B [Earthed])
Up side down outlets-dual-10-horizontal-outlet.png   Up side down outlets-dual-10-vertical-outlet.png
FrodoOne is online now   Reply With Quote
Old 04-27-2016, 06:34 AM   #39
Rewards Points: 1,330
When I was going to school (a loooooong time ago) for electrical training, the instructor taught us to always hook up the ground wire first, neutral second and the hot last (kind of forgot why now). Since most people are right handed, this always put the receptacle in the ground pin down position which then went into the box that way. One guy in the class was left handed so doing what he was told his wound up ground pin up. Aver since then some of us around here refer to ground pin up recept as being done by left handed electricians.
Besides, if you go pin up, you cant do this... yes, I posted the clean version
danpik is offline   Reply With Quote
The Following 2 Users Say Thank You to danpik For This Useful Post:
Nik333 (04-27-2016), oh'mike (04-29-2016)
Old 04-27-2016, 07:13 AM   #40
Rewards Points: 518
Originally Posted by TimPa View Post
I asked a commercial ol' timer electrician who was installing them that way, the answer he gave me was -
"when the receptacle has the metal style cover, should the retaining screw ever come out, the plate would drop down and it would short the hot and neutral"
how would that happen ? the plate would fall down and never come close to the wires on the screws ? just a thought never happen
del schisler is offline   Reply With Quote
Old 04-27-2016, 08:29 AM   #41
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
It would hit the blades of the partiality inserted plug.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following User Says Thank You to jbfan For This Useful Post:
TimPa (04-27-2016)
Old 04-27-2016, 11:59 AM   #42
Oso954's Avatar
Rewards Points: 1,362
Just use this one, it should satisfy everyone. :-)
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 04-27-2016, 05:11 PM   #43
Jello Wrangler
Rewards Points: 539
A broken attachment...that is the opposite of satisfying.
Old 04-29-2016, 07:24 AM   #44
Rewards Points: 518
their are lot's of if's here, if the plate fell to the right and the tip and left were to totch that should be ground and ground ? if hook up right way if it fell the other way may short , , if hook up wrong or right to many if's here and this post is going no where i can see , most are plastic , but some are metal so again lot's of if's again oh well that make's for lot's of post's been in electric back in 1947 and little before , lots of changes
Old 04-29-2016, 09:04 AM   #45
jbfan's Avatar
Rewards Points: 552
I was just answering his question, and I agree with you. Way too many if's.
del schisler (04-30-2016)
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
do I need GFI for all kitchen counter outlets DanDaMan Electrical 2 03-06-2011 06:33 AM
bathrooms and outdoor outlets not working maybecalifornia Electrical 1 03-04-2011 06:24 PM
Basement Outlets Atskodinski Electrical 5 12-14-2010 10:16 PM
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 06:19 PM
