Up Side Down Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2016, 10:55 AM   #1
Ozarka88's Avatar
Rewards Points: 22
Up side down outlets
Doing some maintenance work and noticed all the outlets are up side down. Why is this? I've always just seen them with the ground prong pointing down.
Ozarka88 is offline   Reply With Quote
Old 04-25-2016, 10:58 AM   #2
Rewards Points: 114
Re: Up side down outlets
I'm really curious about this I've seen it myself. I read once it was for ones controlled by light switches. Then I read it was because when the installer picked up the first one of the building he put it in that way. :P
I'm seeing them sideways these days too.
Am curious if there's anything meant to be meant by it..
Phases is offline   Reply With Quote
Old 04-25-2016, 11:03 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
They're not upside down. There is not a code on which way the receptacles are to be mounted, but I agree, they are upside down!!
Some times they are mounted that way to denote switched outlets, or job specs require them to be mounted that way.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 04-25-2016, 11:04 AM   #4
Rewards Points: 516
There isn't a real reason for it. Some put a switched outlet upside down and all constant hots right side up. Some feel it's safer because they believe the ground is more likely to be the "first make, last break."
Arrow3030 is offline   Reply With Quote
The Following 3 Users Say Thank You to Arrow3030 For This Useful Post:
Know A Little (04-25-2016), Ozarka88 (04-25-2016), ZZZZZ (04-26-2016)
Old 04-25-2016, 09:58 PM   #5
dmxtothemax's Avatar
Rewards Points: 7,326
It's so the electric don't leak out all over the floor !
dmxtothemax is online now   Reply With Quote
The Following 3 Users Say Thank You to dmxtothemax For This Useful Post:
joecaption (04-25-2016), r0ckstarr (04-25-2016), ZZZZZ (04-26-2016)
Old 04-25-2016, 10:05 PM   #6
Rewards Points: 17,826
I install all mine that way.
So much easier to plug something in even in the dark.
Most plugs have a hump on the plug, why have to twist the cord to plug it in?
Old 04-25-2016, 10:11 PM   #7
I have heard one possible explanation
thou I find it a bit far fetched !
If something was to fall onto the plug
and get in between the plug and recepticule
then it could cause a dangerous short,
so they put them the other way around to prevent this.
Old 04-25-2016, 10:18 PM   #8
Jello Wrangler
Rewards Points: 539
How often are you plugging stuff in while it's dark? It must be often enough to install all of your outlets this way.
It would drive my OCD nuts. Plus the screws have to go in the same direction as the device. Vertical device, vertical screw...
ChiTownPro is offline   Reply With Quote
The Following User Says Thank You to ChiTownPro For This Useful Post:
J. V. (04-26-2016)
Old 04-25-2016, 10:27 PM   #9
Rewards Points: 516
I don't like 'em ground up because it looks like upside down faces. It's also why I don't like T-slots, I don't like my walls winking at me.
Old 04-25-2016, 10:37 PM   #10
Super Moderator
joed's Avatar
Rewards Points: 22,722
I have at least one fridge that the cord would not hang proper with the plug that way. It would go up and then bend down.
Old 04-25-2016, 11:08 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 574
I remember an electrical contractor getting excited when he found one of his apprentices installing ground up. Turns out the apprentice just came from some medical job- there, the specs said ground up.
So the supt. runs off and reads his specs-- yep, ground up on his job too. Seems the apprentice was right- doesn't happen often...
The Following 4 Users Say Thank You to TheEplumber For This Useful Post:
jbfan (04-26-2016), lenaitch (04-26-2016), oh'mike (04-26-2016), ZZZZZ (04-26-2016)
Old 04-25-2016, 11:31 PM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 9,036
Who wants to look at a sad face.....I like the happy face
The Following User Says Thank You to ddawg16 For This Useful Post:
sgip2000 (04-28-2016)
Old 04-25-2016, 11:38 PM   #13
Rewards Points: 1,408
It doesn't have to be often at all. If one choice offers a marginal safety increase once in the lifetime of a plug and the other doesn't, and there's no significant difference in terms of the install, the responsible choice is the one that's marginally safer.
Tom738 is offline   Reply With Quote
Old 04-26-2016, 12:10 AM   #14
Jello Wrangler
Rewards Points: 539
Where did he mention safety? It sounded more of a convenience to me.
But I will bite, what marginal safety increase does it offer and where did you find your data to come to that conclusion?
And I will counter. If you found out that wearing a tin foil cap would protect you from a 1 in a million chance of getting brain cancer from your cell phone can I expect that you would be wearing the foil hat? It's a silly assertion when there is no measurable difference as well as no quantifiable standard. What would be considered marginal.
Plus there is something to be said about the safety in a consistent standard. I would wager that consistent orientation (up is the current norm) would be marginally safer than upside down (not the current norm). It would be the same reasoning as making steps a consistent height with in a set of stairs and having a universal max height 7 3/4".
Old 04-26-2016, 05:32 AM   #15
Rewards Points: 109
Army house only the switched outlets are upside down. Actually been like that in my last 3 homes all 3 different builders so I assumed it was standard practice to easily identify the switched ones. Top one is switched bottom is always hot..... At least that's how's it is here.
Olcrazy1 is offline   Reply With Quote
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
do I need GFI for all kitchen counter outlets DanDaMan Electrical 2 03-06-2011 06:33 AM
bathrooms and outdoor outlets not working maybecalifornia Electrical 1 03-04-2011 06:24 PM
Basement Outlets Atskodinski Electrical 5 12-14-2010 10:16 PM
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 06:19 PM
