Unplugging Device Interrupts Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 06-06-2009, 09:25 PM   #1
Unplugging device interrupts circuit
Hello everyone! When I unplug a device from one outlet on a given circuit, everything else plugged into that circuit (TV, cable receiver, a couple other small electronic devices) resets as the power is momentarily cut off. This behaviour only started in the last week and nothing has been added to this circuit in over a year (in fact I removed some devices as I thought perhaps the load was too high). I know absolutely nothing about electrical matters, but was hoping somebody might be able to provide at least an idea of what might be happening here before I call an electrician. I'm just somewhat concerned from a safety perspective - in the interim, I will not be using the outlet in question. Thanks and I apologise if there is an obvious answer or if this type of question is not appropriate to ask in this forum.
a_mac is offline   Reply With Quote
Old 06-06-2009, 10:49 PM   #2
Rewards Points: 1,016
Loose wire in the one outlet, other outlets are wired after it and being affected?
Turn of the circuit breaker that powers the outlet (or just drop the main breaker). After ensuring no power from the outlet, remove the cover, then pull out the outlet - check for loose wires.
If back-stabbed (wires go into holes in the back of the outlet rather than being attached to the screws), that can be a problem - move the wires to the screws.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 07:21 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
