Underground Electric - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2010, 06:26 PM   #1
underground electric
Can i run 10 gauge aND 12 GAUGE WIR IN THE SAME CONDUIT TOGETHER
pepsi3656 is offline   Reply With Quote
Old 05-20-2010, 06:31 PM   #2
Electrician 30 yrs +
yes. yes you can.
huck is offline   Reply With Quote
Old 05-20-2010, 07:02 PM   #3
Master Electrician
as long as both wires are fed from the same source.
andrew79 is offline   Reply With Quote
Old 05-20-2010, 08:14 PM   #4
And as long as you aren't feeding a detached structure
THWN or some other wire rated for underground installation must be used
NM can't be used
Old 05-20-2010, 08:48 PM   #5
Just call me Andrew
Rewards Points: 1,032
What type of wire, and what is this for?
Andrew
secutanudu is offline   Reply With Quote
Old 05-21-2010, 12:38 PM   #6
UF wire and its for pool pump and light for the pool
Old 05-21-2010, 12:40 PM   #7
Just call me Andrew
I don't think you're supposed to sleeve a long length of UF in conduit - be better off with individual THWN wires.
Andrew
Old 05-21-2010, 12:52 PM   #8
Where is the wire going to ?
Just a post out by the pool ?
You can sleeve UF for protection, but you need bigger conduit
What distance are you running ?
Old 05-21-2010, 12:58 PM   #9
1" conduit and 10 gauge going to the pump and 12 gauge going to the light in the pool
Old 05-22-2010, 03:42 AM   #10
" Euro " electrician
frenchelectrican's Avatar
Now you allready raise new issue here.
I am not sure if you are aware there is a very strict code cover on pool electrical system.
First thing ., you can NOT use the UF to the pool pump or pool luminiare at all this is covered in NEC code
Second thing you can not use bare conductor at all for pool useage again this is in the NEC code as well.
Merci,Marc
Thrid thing just about everything on pool system it have to be on GFCI either breaker or receptale depending on the set up { yeah there is GFCI requirement on 240 volts pool pumps now but I do not know if some states do cover this requirement or not }
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 09:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
underground water and electric handifoot Electrical 9 05-06-2009 09:13 AM
Design an outside underground electric system??? antiqking Electrical 6 09-13-2008 10:28 AM
