Undercabinet Outlets: On A Budget. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 12:01 PM   #1
Rewards Points: 256
undercabinet outlets: on a budget.
I would like to install undercabinet outlets and lighting.
I don't like the way outlets mess up the look of beautiful back splashes.
I am thinking about just using EMT conduit and metal boxes under the cabinets.
Has anybody ever seen this done/done this?
I think that the angled surface mount modular systems I've seen are too expensive.
Disclaimer: I am a qualified non-licensed homeowner who is legally allowed to do this work with a permit.
Please do not tell me to hire a pro or consult my inspection department(yes I will do that)
michaelcherr is offline   Reply With Quote
Old 08-12-2013, 12:14 PM   #2
Electrical Contractor
kbsparky's Avatar
Wiremold boxes and raceway would look much better under a cabinet --- and the color would match much better than EMT would ...
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
djlandkpl (08-12-2013)
Old 08-12-2013, 12:20 PM   #3
Rewards Points: 256
I forgot to mention that I will be putting trim around the bottom of the cabinets so they will be more hidden than standard.
Will think about wire mold. Thanks for the suggestion.
Old 08-12-2013, 01:51 PM   #4
Oso954's Avatar
Rewards Points: 1,890
Are you just adding outlets, or are you trying to put the outlets required for counter top areas up under the cabinets as well ?
I believe the current height requirement is no more than 18 inches above the counter top for the receptacle to count as a required counter top receptacle.
Also be aware that if you are removing an existing outlet from the back splash area, you cannot just remove the outlet, splice the wires together, and then bury the junction box. The connections would have to remain accessible.
Oso954 is offline   Reply With Quote
Old 08-12-2013, 02:06 PM   #5
Rewards Points: 256
It's a full gut remodel.
Old 08-12-2013, 02:38 PM   #6
Master Electrician
Rewards Points: 5,376
More like 20". Use plugmold
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
stickboy1375 (08-12-2013)
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
Undercabinet outlets JakAHearts Electrical 7 06-06-2010 10:51 AM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
