DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   undercabinet outlets: on a budget. (https://www.diychatroom.com/f18/undercabinet-outlets-budget-185164/)
michaelcherr 08-12-2013 12:01 PM
I would like to install undercabinet outlets and lighting.
I don't like the way outlets mess up the look of beautiful back splashes.
I am thinking about just using EMT conduit and metal boxes under the cabinets.
Has anybody ever seen this done/done this?
I think that the angled surface mount modular systems I've seen are too expensive.
Disclaimer: I am a qualified non-licensed homeowner who is legally allowed to do this work with a permit.
Please do not tell me to hire a pro or consult my inspection department(yes I will do that)
kbsparky 08-12-2013 12:14 PM
Wiremold boxes and raceway would look much better under a cabinet --- and the color would match much better than EMT would ...
michaelcherr 08-12-2013 12:20 PM
I forgot to mention that I will be putting trim around the bottom of the cabinets so they will be more hidden than standard.
Will think about wire mold. Thanks for the suggestion.
Oso954 08-12-2013 01:51 PM
Are you just adding outlets, or are you trying to put the outlets required for counter top areas up under the cabinets as well ?
I believe the current height requirement is no more than 18 inches above the counter top for the receptacle to count as a required counter top receptacle.
Also be aware that if you are removing an existing outlet from the back splash area, you cannot just remove the outlet, splice the wires together, and then bury the junction box. The connections would have to remain accessible.
michaelcherr 08-12-2013 02:06 PM
It's a full gut remodel.
brric 08-12-2013 02:38 PM
More like 20". Use plugmold
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
