Under Cabinet Wiring Issue? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 03-30-2019, 02:22 PM   #16
Rewards Points: 1,351
Re: Under cabinet wiring issue?
Does the lamp have its own plug?
huesmann is online now   Reply With Quote
Old 03-30-2019, 02:31 PM   #17
Rewards Points: 54
It used to have a 2-pronged plug until I cut it off.
farmerjohn1324 is offline   Reply With Quote
Old 03-30-2019, 03:02 PM   #18
Licensed electrician
Rewards Points: 3,592
I don't really see that as a problem as long as your connection is correct, with an accessible panel.
Despite your view it is now an unlisted fixture and a code violation to use it in a way it was not designed.
Old 03-30-2019, 03:32 PM   #19
A "Handy Husband"
rjniles's Avatar
Rewards Points: 388
You are giving bad advice. This site encourages code compliant work and this discussion does not comply.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 03-30-2019, 04:21 PM   #20
Rewards Points: 1,502
anything wrong with putting an outlet in the back of a cabinet, getting a replacement male plug, and just plugging it in like itís supposed to be?
ryansdiydad is offline   Reply With Quote
Old 03-30-2019, 05:03 PM   #21
Rewards Points: 2,556
No, but receptacles in a kitchen must be on a 20a circuit, gfci protected.
LawnGuyLandSparky is offline   Reply With Quote
Old 03-31-2019, 12:46 AM   #22
Rewards Points: 54
anything wrong with putting an outlet in the back of a cabinet, getting a replacement male plug, and just plugging it in like it’s supposed to be?
I didn't do that because the cord was so long it would have been weird. That's what I would do if I had a shorter cord. It has this weird connector that I've never seen before...
Old 03-31-2019, 12:53 AM   #23
Rewards Points: 54
Isn't that only if they serve the countertop?
Old 04-03-2019, 03:06 PM   #24
Pro Answers
Rewards Points: 118
I have used these before when dealing with under kitchen cabinet wiring that is being fed by NM-B 15/20 amp circuit:https://www.amazon.com/GE-39971-Conv...gateway&sr=8-1
Depending on your lighting needs: task vs ambiance there are some simplier solutions like : PUCK battery operated lighting, LED wireless lighting
jmig7 is offline   Reply With Quote
Old 04-03-2019, 08:12 PM   #25
I made my own undercabinet lights using 12 volt LED tape strips. I got a dimmer for $4, strips were a few dollars. A power supply in the cellar runs the lights, and a few others around the house. Low voltage wiring connects them.
vandamme is offline   Reply With Quote
Old 04-03-2019, 10:44 PM   #26
samjg1's Avatar
Rewards Points: 248
How is that box even legal?
samjg1 is offline   Reply With Quote
Old 04-04-2019, 10:16 AM   #27
Why wouldn't it be?
Old 04-04-2019, 11:41 AM   #28
"This junction box only works with GE-branded linkable puck and bar fixtures."
Potential Major Wiring Issue for the Experts icandousa Electrical 5 01-18-2017 01:32 PM
Velux skylight wiring issue leerube Electrical 1 05-05-2016 12:55 PM
Adding wiring for under cabinet lights from a three way switch Dale8 Electrical 0 10-07-2012 02:50 PM
Wiring for under cabinet lighting fredm54 Electrical 15 06-16-2012 12:23 PM
GFI wiring issue voless Electrical 4 10-20-2010 01:37 AM
