Unconnected Cable- Code Problem? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2010, 06:28 PM   #1
Rewards Points: 97
unconnected cable- code problem?
in my quest to improve the wiring, i needed to rerun a new cable from an outlet to a new switch location. that turned to be easy...now the problem is the old cable that i have to leave behind, albeit un-connected at both ends. obviously the cable is stapled to 2x4s.
so- is there any code violation if i leave unconnected (at both ends) cable behind sheetrock?
thanks
drgkjd is offline   Reply With Quote
Old 06-02-2010, 06:55 PM   #2
Rewards Points: 6,652
As long as both ends are taped, and not in the box to be able to be reconnected at either end.
The Following User Says Thank You to gregzoll For This Useful Post:
drgkjd (06-03-2010)
Carrier 58MXA Code 31 Problem MikeZ HVAC 8 01-12-2010 06:32 AM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 09:04 AM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 08:00 AM
is stapling cable to beams/studs a code req ? amakarevic Electrical 11 07-03-2008 08:42 AM
Transformer Help chcustom Electrical 28 12-10-2007 10:40 PM
