UGH! Moister In The Electric Box -- Odd Things Lots Of Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2010, 10:53 AM   #1
UGH! Moister in the electric box -- odd things lots of questions
The only circuit that has ever tripped on us is the one we can overload. Rewiring the house will fix that...(which might happen sooner than I want).
We turned off our power. Cracked open our circuit box. Picture of my a/c circuit is attached. It was right beside the range circuit and it is in bad shape heavenly corroded. The prongs these were attached to were corroded and rusted. There was moisture in the box but only on these two circuits and the one right below it.
Called an electrician, I know when the job is to big, he asked about moister/water in the box and over hanging wires. We looked, there was no moister any place in the box. Since it was raining and I had a moment of stupidity I felt the wire into the house. It was DRY. It was only in that spot on the circuit breaker panel. Could the moister be coming from the basement itself? It can be damp. I was wondering since these things had to be hot if it caused condensation to occur and that is why the water damage is only there.
The next set of question is why did none of these circuits trip? There was a 40 amp besides and 60amp. The 40 amp has melt damage but it was not tripped. I feel lucky that I hadn't turned on my a/c for the year.
There is enough corrosion (along with obsolete replacement circuits) to the prong that a new entry will need to be installed. What should I expect? I don't want to get hosed over. I do have electrical backgrounds but that is in control towers not home wiring. So I have enough information to be dangerous.
UGH! Moister in the electric box -- odd things lots of questions-photo-0012-1-.jpg
ReginaBing is offline   Reply With Quote
Old 05-16-2010, 11:31 AM   #2
What Mfg panel do you have ?
Old 05-16-2010, 11:49 AM   #3
It is a Sylvaina
Old 05-16-2010, 05:54 PM   #4
Rewards Points: 1,910
I suppose the corrosion might have prevented the breaker from tripping. If you're concerned about the electrician's bill all you can do is have a couple electricians look at it and give you a quote. But make sure the electrician is competent as that is far more important than the bill. A poor electrician with a low quote will end up costing you a lot more than a good electrician with a higher quote. Make sure the source of the moisture is identified and corrected or it will happen again.
Old 05-16-2010, 07:10 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
That looks like a stab lok in full action. :P
Did you check the main conduit that comes from outside if there's any way water can get into it? I would suspect that,and it just happened to hit those breakers. Though it could be what you say where water condensed on it if they were hot.
Old 05-16-2010, 07:19 PM   #6
Unhappy
To me it looks (and, not surprisingly) acts like a stab-lok. The entire panel should be replaced, and the source of the moisture checked out.
spark plug is offline   Reply With Quote
Old 05-17-2010, 01:09 AM   #7
" Euro " electrician
frenchelectrican's Avatar
With that much damage to the breaker It will be wise to justify the cost to get new load centre due you mention Sylvaina breakers that is pretty old style breaker it will be simauir to either challanger or zinsco breakers.
The best answer is get new load centre and have a electrician to check out the riser or any entrance points and see if the water did get into some reason.
Merci,Marc
Old 05-17-2010, 08:24 AM   #8
I've seen the feed, panel & breakers all replaced, paid for by Insurance company
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
Questions about electric water tank Piedmont Electrical 4 08-15-2008 02:51 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
Considering Cork for Basement ... LOTS of questions! :) njchan Flooring 5 01-26-2008 08:05 PM
new home owner with lots of questions later dark7068 New Member Introductions 3 11-10-2007 10:36 AM
