Two Switches Plus An Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2009, 01:24 PM   #1
Rewards Points: 79
Two switches plus an outlet?
In my bathroom I currently have a switch (controls the exhaust fan) and GFCI outlet combo. I'd like to replace the exhaust fan with a fan/heat lamp combo, but the fan/heat lamp would need two switches. I can't put in a wider box due to some obstructions -- do they make a 2-switch/GFCI outlet combo for a standard-size box?
thebigsee is offline   Reply With Quote
Old 12-03-2009, 01:36 PM   #2
300zx's Avatar
Post
I have not seen one with 2 switches.Can you put a cut-in box above or below the switch you have now? The only GFCI with a switch i have seen has been a single switch on a GFCI
300zx is offline   Reply With Quote
Old 12-03-2009, 02:11 PM   #3
Rewards Points: 18
ok, I'm no expert here, but I believe a gfci protects downstream outlets on the same circuit. If so, depending on your circuit, you may be able to locate the gfci at an outlet upstream from your bathroom outlet. Then you are just left searching for a 2 switch outlet combo (no gfci because it is taken care of upstream) which might be easier to find.
markinmich is offline   Reply With Quote
Old 12-03-2009, 02:38 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,444
If you are adding a heat lamp, chances are it calls for a dedicated circuit.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 12-03-2009, 03:45 PM   #5
Licensed electrician
Rewards Points: 3,742
IIRC the bulbs are like 250 watts apiece. This would be adding over 4 amps to whatever else is already on the circuit. This may cause the breaker to trip while using a blow dryer or curling iron.
Old 12-03-2009, 05:33 PM   #6
Rewards Points: 79
I think it's a good point about a dedicated circuit for the heat lamp/exhaust fan -- I'll hire an electrician for this one, probably will just convert the switch/outlet combo to two outlets and then put two switches on its own circuit above it.
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Power through outlet to two single pole switches aaronmoon Electrical 2 08-12-2009 08:29 AM
adding outlet from light switch tad Electrical 17 06-05-2009 11:25 PM
One outlet four switches SoonerMike Electrical 8 01-08-2009 05:37 AM
Dead outlet and switches on otherwise live circuit viking1974 Electrical 4 08-23-2007 05:30 PM
