Two Single Pole Switches Connected - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2014, 03:25 PM   #1
Rewards Points: 8
I am replacing some old switches in my house and came across a setup that seemed a little strange. It's a two gang box with two single pole switches (picture is attached). The left one controls a fan/light combination. The right one does not seem to do anything. I am a little confused about the wiring since the right switch does not have any outgoing wire and instead has two incoming wires, one of which is connected to the other switch. What is going on here? My guess is that the wiring was done in a way that avoids having to pigtail, but I am not sure. Thanks.
snahdog is offline   Reply With Quote
Old 10-25-2014, 03:53 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 90
Power comes into the box and connects to 1 switch, bridged to the second switch and then leaves to box to another location.
The switch on the right has nothing connected to the other pole, hence it does nothing.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 10-25-2014, 04:09 PM   #3
Rewards Points: 528
Send a message via AIM to theatretch85
The switch on the right probably controlled a switched outlet in the room. Someone likely didn't want the outlet controlled by the switch and moved the wire from the top push-in to the bottom, effectively bypassing the switch function. If you disconnect the wire at the push-in/back-stab you can see what does and doesn't work. It probably controls half of an outlet near the switches, or half of all the outlets in the room.
theatretch85 is offline   Reply With Quote
Old 10-25-2014, 07:50 PM   #4
Rewards Points: 8
Thank you. I checked and the wire coming out of the right switch does indeed control some outlets. I would like to keep it that way (i.e. have the outlets always on), but also completely remove the right switch and replace it with a blank. I was thinking of doing the following: Remove the right switch completely. Then remove the two bottom wires from the left switch. Pigtail the wire that was coming into the bottom of left switch with the wire that was leaving the bottom of the right switch and connect it to the bottom of the left switch. Is that a correct/safe way of doing it?
Old 10-25-2014, 09:18 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 29,504
Two remove the right switch simply remove the two black wires and nut them together.
Old 10-26-2014, 02:12 AM   #6
Rewards Points: 528
This is the preferred way to accomplish what you are looking to do. They do make the blank switch inserts so you can keep the double gang face plate in the event you ever want to put the second switch back in.
Tags
light switch , single pole , wiring
Change 2 three way switches into one single pole switch ColdYeti Electrical 0 06-29-2012 01:51 PM
Help with single pole switch that has me baffled NABRIL Electrical 19 03-12-2012 06:37 AM
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 01:39 PM
Re-wire dual pole switch to single pole bujaman Electrical 3 05-31-2011 07:09 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
