Two Quick NEC Code Questions - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 01:44 AM   #16
" Euro " electrician
frenchelectrican's Avatar
Also what I do is mark the circuit number inside the junction box as well in case someone fuber'ed the cover all I do is go back and look at the junciton box where I scribble in the circuit number.
It came handy more than once in couple resdentail home I work on many years ago and common in commercal location { it pretty much mantory anyway }
Merci,Marc
Old 06-15-2009, 10:19 AM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Your going to find that most panels that have been installed for a few years are so screwed up as for the labeling that your only choice is to make a new index. I used to open an excel spread sheet and build a new index for the customer then have it laminated. Typical manufacturer labels can in no way allow you to itemize what is on a branch circuit in most homes that have been messed with.....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 06-15-2009, 11:47 AM   #18
Originally Posted by theatretch85 View Post
I believe to be code compliant your spreadsheet label must be on the inside of the panel door or on the face of the panel cover, not on the wall next to it. This may be a jurisdictional thing, as my inspector said that I couldn't have it on the wall next to the panel (even though it was close enough that the paper and the tape was actually touching the panel). I like the spreadsheet idea myself, I only indicate the ampacity of the circuit and the function, all the breakers match the wire size of the entire circuit (at least as far as I know).
Inspector has been here 2x, he liked the spreadsheet idea
Maybe some would find fault with it
Yeah, the panel at my last house was a mess
Old 06-15-2009, 12:33 PM   #19
Rewards Points: 528
Send a message via AIM to theatretch85
I didn't say there was anything wrong with the spreadsheet idea, just with the placement of it. If your inspector hasn't said anything about it needing to be on the panel cover then i'd say your ok. I just know my inspector had a problem with it being on the wall next to the panel verses on the panel door (seems like a stupid thing to worry about, but whatever).
The spreadsheet certaintly allows for a much cleaner label and so long as you save the file someplace safe you can edit it when you alter or add additonal circuits. After a panel has been in use for a number of years, the original factory label tends to crumble and flake off or the pencil markings tend to fade and become un-readable.
theatretch85 is offline   Reply With Quote
Old 06-15-2009, 07:53 PM   #20
Learning by Doing
Leah Frances's Avatar
I had to open my Grandmama's breaker box to kill the power to replace a broken switch. My first shock (not literally ) was that it is on the OUTSIDE of her house. My second (no shock, I suppose) was, that of the six circuits only two were labelled, from the original install. It took my mother, two cell phones, and five breaker throws to find the circuit I needed.
BTW, I label every JBOX with the corresponding breaker number, I also label every rec and switch, the same. And, because, well, you can never have too many labels, I also label cables where they exit and enter JBOXs, walls, etc.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-15-2009, 09:01 PM   #21
DIY'r
ScottR's Avatar
I'd like to call you crazy.. But I do the same thing.
Well, I don't label switches or counter top receptacles.. But the rest is true.
ScottR is offline   Reply With Quote
Old 06-15-2009, 09:06 PM   #22
Learning by Doing
Put more than three switches in a gang. You'll want to label them too.
[I don't gang more than two switches for this reason - in my parent's house my dad has several gangs of threes and fours. Even after living in the house for 10 years - I still can't tell you which switch does what. My neighbor's new build house has three different gangs with six switches - all labeled.]
Old 06-15-2009, 09:20 PM   #23
I only use quad boxes, but I use duplex switches
I never use the triple boxes or larger, just don't like the look
So I have a number of places that have 3 switches
I don't label any of them
The front door has a triple switch on one side, hall light/front porch/post light
Then on the other side is a dual switch for the fan/light
Old 06-15-2009, 11:16 PM   #24
Registered User
Rewards Points: 526
For the op, a day late and a dollar short:
http://books.google.com/books?id=lrS...esult&resnum=5 Be safe, G
couple of code questions ponch37300 Electrical 9 01-26-2009 10:45 AM
Handrail building code questions - Canada Peterpantz Carpentry 7 10-26-2008 12:24 PM
Quick cabinet painting questions jimithing78 Painting 2 08-20-2008 12:46 AM
Michigan code questions rondo Electrical 1 12-22-2005 10:37 PM
