Two Hot - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 05-06-2012, 07:57 PM   #61
FYI, you could have taught me instead of mocking my lack of knowledge. I didn't come here for that. I came to learn.
thereverendz is offline   Reply With Quote
Old 05-06-2012, 07:59 PM   #62
Rewards Points: 6,652
Originally Posted by thereverendz View Post
Yes, but I am essentially checking for resistance. Zero resistance would imply continuity. Right?
No. It just means that you did not complete the circuit. Infinity means that you have a completed circuit, or more resistance than the meter is able to tell you.
Old 05-06-2012, 08:03 PM   #63
Nobody is mocking anyone. I have stated this before for others. I tend to anymore just lay it out on the table and tell it like it is, other than sugarcoating like some, or trying to play guessing games, or play who is bigger than the person coming for help. Sort of like some that have the David & Goliath complex.
Old 05-06-2012, 08:06 PM   #64
"That is a first. Never knew that you could use resistance to figure out a ac electrical circuit."
Come on, you know very well that this a perfect example of sarcasm. I don't really care to argue over the fact, but as someone who came here to seek knowledge, I really didn't appreciate the comment. You could have just explained it as you did in a later post. Your constructive comments are appreciated though.
Old 05-06-2012, 08:20 PM   #65
I=E/R
a7ecorsair's Avatar
Yes, that is correct.
a7ecorsair is offline   Reply With Quote
Old 05-06-2012, 09:37 PM   #66
No, that is not sarcasm. You can not use resistance to figure out a electrical circuit. There is a correct way of doing things, and as I have already stated over and over, a wrong way or a way of over thinking things like most people on the Internet tend to do, when posting on BBS type forums. Anymore, it is starting to appear that most that post out on the Internet asking questions, but over thinking problems, just need to stop and use K.I.S.S process.
I myself tend to over think stuff, but I get paid to think outside of the box for a living, same when I was in the Navy solving a majority of the issues that others would not fix. I could get the problem resolved and move on to the next job.
Old 05-06-2012, 09:57 PM   #67
I=E/R
a7ecorsair's Avatar
If you two are through arguing then think about this:
Resistance is a measurement where continuity is a condition.
The Following User Says Thank You to a7ecorsair For This Useful Post:
thereverendz (05-06-2012)
Old 05-06-2012, 10:07 PM   #68
a7, across from, next to, if your breaker box is 120x2, then 240 can be found between any two points, that was my point.
greg, yes, explanation kinda confusing, how many megs are code now?.
trv, continuity and resistance are similar in concept. Zero resistance = full continuity. Using a normal meter uses dc current. What we are looking at is ac. Never use your meter to calculate anything. These tests only suggest anwsers, not prove them. Think of a massive long water pipe that you cap on both ends, then add a little water pressure thru one side and measure the resultant pressure on the other. All you can deduce is that both ends are connected, not the volume of water that can flow thru the pipe.
jb64 is offline   Reply With Quote
Old 05-06-2012, 10:41 PM   #69
Two types of volt meters, analog and digital, both have strenghts and weaknesses
Analog Plus:
Perfect to test caps
Good for absolute testing
Analog minus:
Gotta pay attention
Digital Plus:
can measure anything with a super high internal resistance (impedance)
Little skill required
Digital minus:
The super high internal resistance can't even "bleed off" radio or earths magnetism. If you don't believe me wave your test leads, you'll drive it crazy, auto range flying, readings over 1 volt from nothing.
Connect one lead to a live wire, leave the other free(the free lead will possess the voltage of the live one) and its no telling what the display will reveal.
Old 05-06-2012, 11:13 PM   #70
Analog Plus:
Analog minus:
Gotta pay attention
Digital Plus:
Digital minus:
Can you explain the analog pluses?
Old 05-07-2012, 01:25 AM   #71
" Euro " electrician
frenchelectrican's Avatar
There is, if it does not pass a MegOhm test.
Greg.,
The other common term for MegOhm is Megger and I used pretty often over my area ( In France ) so I can able weed out bad cables espcally with older BX it will fail useally found in junction boxes that is the most common place I will find it but from time to time middle of run it will show up as well.
Merci,
Marc
Old 05-07-2012, 07:59 AM   #72
Sorry, I don't really understand this question.
Old 05-07-2012, 08:00 AM   #73
Test caps? Absolute testing?
Old 05-07-2012, 08:23 AM   #74
"Absolute" kinda a silly word, I just meant there is no auto ranging so you can't miss the unit display, missing m or k or M can have serious consequences.
Test Caps, sure, not for their capacitance value but for good/bad, pass/fail type test.
Tags
help please , two hot wires
