Two Ground Screws In One Jb - Electrical - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By joed
  • 1 Post By joed
  • 1 Post By Bria Johnn
Old 04-11-2017, 09:08 AM   #1
Rewards Points: 54
Two ground screws in one jb
In Canada here...I've seen electricians use two ground screws in one box, factory design.Question is this...is it appropriate to use two separate ground screws for two separate circuits in a junction box?The junction box itself is a transition point from romex to conduit.
J.Fanton is offline   Reply With Quote
Old 04-11-2017, 09:32 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,854
Re: Two ground screws in one jb
It makes no difference. All grounds need to be connected from all circuits.
Bria Johnn and J.Fanton like this.
Old 04-11-2017, 01:59 PM   #3
Rewards Points: 54
Hey thanks for the reply...so using both ground screws in the box is permitted?
Old 04-11-2017, 02:15 PM   #4
Super Moderator
joed's Avatar
Absolutely. And since the screws have a shoulder beside them on the box, two wires per screw is permitted. Do not wrap just slide one on each side of screw and tighten.
J.Fanton likes this.
Old 04-11-2017, 08:03 PM   #5
Rewards Points: 390
An instructor once told me Ground is Ground. The metallic connection makes them one and the same.
Bria Johnn is offline   Reply With Quote
Ground wire from panel to ground rod swbrains Electrical 46 09-03-2014 05:05 AM
Grounding Boxes Keep Changing Perry401 Electrical 18 06-13-2014 04:27 PM
How does grounding work? scyarch Electrical 44 06-12-2012 04:59 PM
Fried electronics after earth ground accidentally disconnected oukachiru Electrical 7 07-12-2011 03:05 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
