DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Are twist connectors safe to use for light fixture wiring? (https://www.diychatroom.com/f18/twist-connectors-safe-use-light-fixture-wiring-657879/)
parmesan 04-24-2019 12:31 PM
The electrician I highered said the easiest way to move these switches to another wall was to run them down this column and up the new wall. But the wires were short so he extended them using twist connectors and electrical tape. I will cover them with a think piece of sheet metal to no one can drill a hole on these wires and get shocked but is this safe? Would it be worth redoing everything buy opening up the floors upstairs and using a junction box? (will cost a good bit more obviously)
https://drive.google.com/file/d/1Usp...ew?usp=sharing
https://oi1207.photobucket.com/album...ne/Image-1.jpg
Sdiver2489 04-24-2019 12:57 PM
Re: Are twist connectors safe to use for light fixture wiring?
Oh my...so against code its worth firing who did that.
To do that to code you would have to have all those junctions in a box that is accessible after it is finished.
Oso954 04-24-2019 01:04 PM
Iím having great difficulty believing the guy you hired is any type of electrician.
Thatís about as hack as work ever gets.
mpoulton 04-24-2019 01:13 PM
Absolutely unacceptable. There is no way a competent electrician would do that. Fire the guy. Also consider demanding a refund or refusing to pay and reporting to your local contracting authority. This is incompetent, illegal hack work that wouldn't pass inspection anywhere in the USA and would be embarrassing to show another tradesman. Nobody should be allowed to do that in someone else's house and charge for it.
There is a code compliant solution to this problem: https://www.homedepot.com/p/Tyco-Ele...-000/202204326 These NM cable splice kits are UL listed for use inside an enclosed wall. There are a few competing products like it, but they all work the same way and look similar. No other splicing method is acceptable without being placed in an accessible junction box (i.e. not buried in a wall). All those wire-nut splices with electrical tape need to be removed and replaced with these types of UL listed buried splice kits. By someone other than the moron who screwed it up in the first place.
daveb1 04-24-2019 02:02 PM
Your "electrician" was correct in that wire nuts and tape is the easiest way to extend wires. It is also against electrical code in the US and also Canada.
MTN REMODEL LLC 04-24-2019 02:48 PM
Except... it would have been easier not to have bothered with wirenuts....
KPDMinc 04-24-2019 05:06 PM
you definitely didn't hire an 'electrician'....
friesbruh 04-24-2019 11:13 PM
That looks terrible. It is also unbelievably irresponsible and it jeopardizes yours and everyone's life who lives there now or will after.
He is no electrician. His actions are also unconscionable.
jeffnc 04-25-2019 01:23 AM
Oh my goodness. Please, do your duty and report that guy so that he never does any electrical work again. Call your local permitting office and ask them what to do.
TarheelTerp 04-25-2019 05:52 AM
Originally Posted by parmesan (Post 5819869)
The electrician I highered said...
Where did you find this bum?
CaptTom 04-25-2019 09:05 AM
Totally agree it's a code violation and unprofessional to the extreme.
But, without condoning or encouraging this kind of thing, if the joints are staggered, well connected with wire nuts, secured and protected by good-quality tape, and protected from being pulled or punctured, what's the failure mode?
Don't beat me up; it's just a thought experiment. Could it fail in such a way as to be any more dangerous than the code-approved alternative? I'm drawing a blank.
However, if those are metal staples holding the wires, with no protection from cutting into the insulation, I can see a potential issue there if the wires get some tension somehow.
ktownskier 04-25-2019 09:05 AM
Here is the item that @mpoulton speaks of:
https://images.homedepot-static.com/...00-64_1000.jpg
Here's my nickles worth. I can't say anything else about the work done by the idiot you hired or the work they did that hasn't been said before. Well I could, but this is an open forum. :devil3:
As to how to resolve it.
First, call your appropriate housing authority (Usually the people who gave you your permit. You did pull a permit didn't you?) to report the electrician and to have an inspector come out. If you didn't have a permit, ask if they have their building codes published on-line, including electrical codes.
I am sure that most, if not all, of us would tell you to get a permit pulled for the work being done. If there were a fire in the house at any future time, and it was determined that the wiring that you had hired to do was the cause. Then the contractor would be responsible for cost of the repairs. If you can find him, if not then you. However, if it has passed inspection, then the liability passes of to the inspector and the local housing authority.
I see that you are doing a lot of remodeling work, where is the cable coming from, above or below? Is it possible to put a large junction box there to make the correct connections and then run new cable to the new locations? You could use the cable that the "moron" used. If it is too short, then you can use another junction box to extend the cable. (As long as it is not hidden of course.
If you decide to use the item that @mpoulton pointed out, check the electrical code that your AHJ uses (you asked about it earlier or that you searched for) and check to see if they have made any changes regarding NEC Code - article 334-40b, 2005 and 2008 NEC. As long as they don't say anything about it, then you are okay to use it. Even if your local inspector may not like it. Although they are the final say about it.
The TYCO unit is only a splice, not a splitter. It is hard to see, but it looks like there may be some cable splitting in that mess. Use the TYCO splice and then run the cable to a point where you can use a junction box to make a safe cable split. I like to add an outlet because you always use more outlets.
Sorry for the long post. There is just so much wrong with this situation that I felt the need to include as much information as possible.
Dan
huesmann 04-25-2019 09:22 AM
Even in an accessible panel?
Wiredindallas 04-25-2019 10:09 AM
The way I handle this situation is to add a plug that the original wires will reach, then run new wires from it. Ideally if the old wires come from below so the plug can be at normal height. You can splice wires in the new box without necessarily connecting to a plug.
rjniles 04-25-2019 10:42 AM
Surely you mean a receptacle
Sent from my Moto E (4) Plus using Tapatalk
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
