TV Interference - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 03:36 PM   #1
Rewards Points: 260
TV interference
I'm getting interference on my television every time my condensate pump comes on. The pump is plugged into the same circuit as the tv. It never did this before. Is there anything I can do other than plugging the pump into another circuit (or tv)?
bluefitness is offline   Reply With Quote
Old 07-19-2010, 05:47 PM   #2
I=E/R
a7ecorsair's Avatar
The interference could be noise that is being picked up through the antenna system or noise on the power connection. Are you using an antenna or cable connection? Do you see the interference on all channels? Are you using a converter box?
Try running the TV using an extension cord on a different circuit like one in the kitchen.
a7ecorsair is offline   Reply With Quote
Old 07-19-2010, 09:35 PM   #3
If it's radiated interference wrapping the pump with tin foil that is grounded should reduce it.
If it's conducted through the power line rather than radiated a long extension cord will add inductance and may lessen the interference if this is true.
Or try an RFI filter.
http://www.hosfelt.com/contents/en-u...hphrase=filter
Enter
filter
into the search term box on the upper left.
Radio Shack probably has these.
Old 07-20-2010, 10:34 AM   #4
Rewards Points: 2,800
If the problem started suddenly, maybe you just need to rebond the pump body to ground. (For example the existing grounding may have developed a loose connection.)
If you want to wrap the pump in tinfoil, do not cover openings in the body, which may be needed for motor cooling.
YOu can also ground all of the electronic equipment. Any of the input jack studs, or a screw that goes through the cabinet to the chassis, can be used as an attachment point for a ground wire that daisy chains from one piece to another.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Interference of countertop and door casing dbasmb Kitchen & Bath Remodeling 1 04-05-2010 02:11 PM
TV interference when devices are turned on or off in the home - ideas? rightbryce Electrical 7 09-19-2009 11:43 AM
Repair of Door with Metal Interference Weatherstrip KAdams4458 Carpentry 4 09-18-2009 08:38 PM
Dimmer causing interference - Help scottmatt Electrical 5 04-18-2008 09:08 AM
electrical audio interference?! joeyboy Electrical 10 11-23-2007 12:21 PM
