Trying To Identify Wires... - Electrical - DIY Chatroom Home Improvement Forum
Like Tree8Likes
  • 3 Post By Nealtw
  • 1 Post By JLawrence08648
  • 1 Post By Mercyful_Mike
  • 2 Post By chandler48
  • 1 Post By keep_hope_alive
Old 07-27-2019, 07:38 AM   #1
Rewards Points: 4
Trying to identify wires...
Three #8's pulled for a garage sub panel, but none are marked. Two of the wires are landed on a 2 pole breaker, the other is a neutral. If I turn on the breaker, I can easily identify the two hots. However, I do not know which is A and which is B. My question: can I disconnect one of the wires from the 2 pole breaker, turn the breaker back on, and then test to see which one is hot? That way isolating A from B? Help!
Mercyful_Mike is offline   Reply With Quote
Old 07-27-2019, 07:43 AM   #2
retired framer
Rewards Points: 8,956
Re: Trying to identify wires...
It doesn't matter which is which.
Do not use flat bottom gables with scissor trusses.
Old 07-27-2019, 07:49 AM   #3
Rewards Points: 586
Yes you can do that with a voltage tester, tick tracer.
MTN REMODEL LLC likes this.
JLawrence08648 is offline   Reply With Quote
Old 07-27-2019, 07:51 AM   #4
Rewards Points: 4
Even if the sub panel is a main lug panel?
Nealtw likes this.
Old 07-27-2019, 07:57 AM   #5
Naildriver
chandler48's Avatar
Rewards Points: 1,906
IT doesn't matter. Both are carrying 120 volts and can be interchanged. You know which one is neutral, so you are good.
joed and MTN REMODEL LLC like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 07-27-2019, 08:00 AM   #6
Rewards Points: 58
Sure. Them you can mark 1 with colored tape such as red, but not white, gray, or green. Orange and Brown are usually for high voltage/3 phase.
Wiredindallas is offline   Reply With Quote
Old 07-27-2019, 08:44 AM   #7
Acoustics & Electrical
Rewards Points: 134
Your method would work but it causes unnecessary risks. And as mentioned below it doesn't matter which is A or B. If you move the double-pole feeder breaker up or down a space you've just changed it.
Phase identification matters in 3 phase installations because motor rotation is affected by phase rotation. Single phase installations use induction motors or ECM, not synchronous motors, thus phase rotation isn't a concern.
A safer method to test wiring (if you didn't know what was phase or neutral) would be to pull the wires off the main panel/breaker and simply put a 9V battery between them (alligator clips are handy here), noting polarity. Then when you measure VDC on the other end you'll be able to figure out which is which.
For your installation, just leave it as-is and don't take the risk for no gain.
keep_hope_alive is offline   Reply With Quote
