Trying To Build A Woodburning Unit To Practise Pyrography - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 10:44 AM   #1
Trying to build a Woodburning Unit to practise Pyrography
I know this isn't Home Improvement, but it has to do with equipment typically used in a home, like Nichrome wire and Soldering Guns.
I have this idea to cannibalize a Soldering Gun and use the transformer in there to fab up a DIY Woodcarver. I have the Gun, and also cannibalized some wire out of an old coil-type electrical heating unit, but I must be missing something, the 2" of wire I attached to the Soldering Gun's stubs are not giving me much heat. I even tried reducing the gauge of it by pinging it with a ballpeen hammer. I had a notion of controlling the Soldering Gun's transformer with a solid state light dimmer, thereby reducing the voltage to the secondary, and consequently the heat output.
The VAC out of the secondary is about 1.8 VAC, which I suspect is my problem. I guess the Gun is designed for a steel tip, and the Nichrome wire won't work.
Any ideas?
JLPicard is offline   Reply With Quote
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 36 02-25-2018 11:51 PM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 02:08 PM
Should I relocate my AC unit to build a deck? tom_matthews HVAC 13 06-24-2009 08:12 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 05:10 PM
