Tripped Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2010, 03:31 PM   #1
Question
My microwave is positioned above my stove.My toaster is plugged into the receptacle next to the stove.When I use both simultaneously the circuit breaker trips.Any ideas why this happens?
Red6G is offline   Reply With Quote
Old 06-08-2010, 04:23 PM   #2
Master Electrician
Rewards Points: 5,082
The circuit is overloaded.
brric is online now   Reply With Quote
Old 06-08-2010, 05:30 PM   #3
Yup, my toaster takes at least 850w & it isn't even that big
Both together exceed the circuit capacity
*edit* actually mine does not exceed 2400w, it exceeded 1500w, tripped the surge that I had both plugged into
Old 06-08-2010, 06:07 PM   #4
IIRC, any fixed appliance should be on it's own circuit. In your case, the microwave (i'm assuming permanently mounted above stove) should've been on it's own circuit.
In this case, its clear they are on the same circuit.
Take wattage of toaster plus wattage of microwave, divide by 120, gets you amperage.
eg: 850W toaster + 1500W microwave = 2350W / 120V = 19.58A.
If your kitchen circuits are 20A like it should be, then you are border line maxed out. Appliance startup amps are generally higher. Also circuit breakers are only nominally 20A, almost never exactly 20.000A.
acerunner is offline   Reply With Quote
Old 06-08-2010, 07:53 PM   #5
In a similar situation at least one forum member used a heavy, short extension cord to pick up power for one of the appliances from a nearby outlet that was on a different breaker.
16 gauge cord is rated for 13A but I'd probably go with 14 gauge. If you have AFCIs they may trip if the cord becomes damaged.
Old 06-10-2010, 03:52 PM   #6
This is why its required, and good, to have 2 dedicated electrical circuits to the kitchen counter, 1 circuit for garbage disposal, and 1 for the dishwasher. Hope this helps.
Los Angeles Electrician
Branover Contractors Inc
branover is offline   Reply With Quote
Old 06-10-2010, 04:57 PM   #7
Just call me Andrew
Rewards Points: 1,032
How difficult would it be to run a new wire from the circuit panel to either one of those two outlets?
Andrew
secutanudu is offline   Reply With Quote
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 02:29 PM
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 09:14 PM
Federal Pacific stab-lock circuit breaker Mike in Arkansas Electrical 4 11-29-2009 09:07 PM
Breaker tripped after power outage. What's up? Leah Frances Electrical 14 02-12-2009 06:56 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
