Transformer Next To Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 09-06-2009, 09:18 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
transformer next to panel
I see this often, and also in my own house. What exactly is this for, is it for the door bell?
Old 09-06-2009, 09:31 PM   #2
Usually Yes (bare transformer), or an alarm system (plug in)
Old 09-06-2009, 09:34 PM   #3
dSilanskas's Avatar
Door chime yes
dSilanskas is offline   Reply With Quote
Old 09-06-2009, 10:05 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Most common used for doorbell set up and typically they are useally on 16 Volts AC some run at 12 or 24 volts so watch out on that part if you want to upgrade the doorbell and the size of transfomer most doorbell transfomer useally are about 20VA { voltamps } but you can get larger one if you have more than two doorbell units or a very powerfull doorbell unit.
Merci,Marc
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
