Tracer Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 07:55 AM   #1
Just call me Andrew
Rewards Points: 1,032
Tracer Wire
I am installing a lawn sprinkler system. Should I run a tracer wire with my water pipes? How is it done? Is it simply a piece of wire in the ground or does it need to be tied in to some electrical source?
Andrew
secutanudu is offline   Reply With Quote
Old 07-26-2010, 08:59 AM   #2
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
What kind of pipe????
PVC or black flex?
No it has nothing to do with power so just zip tie the wire to the pipe as you go and your done. You are putting the wire there so in the future you can find the pipe with a metal detector and carefully dig around it.
Big N8 is offline   Reply With Quote
Old 07-26-2010, 09:13 AM   #3
Just call me Andrew
It's black poly pipe. Where can one even get tracer wire?
Andrew
Old 07-26-2010, 09:27 AM   #4
the Musigician
DangerMouse's Avatar
I'd think any old scrap wire would work, but I could be wrong?
DM
Old 07-26-2010, 09:27 AM   #5
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
I wouldn't even run tracer on that kind of pipe. Just run a metal fish tape down the pipe when you want to find it. Way cheaper and equally good.
Or like he said just the cheap wire.
Old 07-26-2010, 09:33 AM   #6
the Musigician
A local discount store around here sells 100' of cheap speaker wire for $1.00, would that work?
(emphasis on cheap, as in thin)
DM
Old 07-26-2010, 09:56 AM   #7
Just call me Andrew
Not sure what you mean...
Andrew
Old 07-26-2010, 10:08 AM   #8
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Well instead of running a wire with the pipe. You can just dig up one of the heads and run the fish tape down the pipe. This will allow you to find it with a metal detector and locate the pipe.
here is what a fish tape is. http://www.homedepot.com/webapp/wcs/...7&marketID=101
Old 07-26-2010, 10:16 AM   #9
Just call me Andrew
Oh, i didn't realize you meant inside the pipe. I have a fish tape :P
Andrew
Old 07-26-2010, 11:01 AM   #10
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Your set then.
Wire tracer DaleB Electrical 0 02-22-2010 07:27 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
