Tool Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 09:57 AM   #1
Tool question
I'm almost too embarrassed to ask but what are screwdrivers with a bent shaft intended for? http://www.mytoolstore.com/ideal/ide12-16.html
PirateKatz is offline   Reply With Quote
Old 02-25-2009, 10:01 AM   #2
Rewards Points: 2,350
They swivel. They are used mostly to run the screws for switches and receptacles. I usually use my drill, but my offset screwdrivers are great for locating obstacles before I cut a box in.
Old 02-25-2009, 10:12 AM   #3
the Musigician
DangerMouse's Avatar
yup, the handles swivel and act as a 'brace and bit' sort of.
DM
Old 02-25-2009, 12:23 PM   #4
Registered User
Termite's Avatar
The screwdriver's shaft spins in the handle. With a little practice they become a very valuable tool.
They're great for doing finish work...Installing devices into the boxes and cover plates specifically.
Old 02-25-2009, 12:52 PM   #5
Rewards Points: 316
Back in the day we called them "yankee" screwdrivers. Time saver on trim out.
Old 02-25-2009, 02:43 PM   #6
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
a wobbler!!! absolutely have to have this on a trim out. i always thought a yankee screwdrive was one that spun automatically when you push on it.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 02-25-2009, 07:57 PM   #7
Man of many hats
wrangler's Avatar
Rewards Points: 354
Man... that brings back memories... the first and last time I saw one of those was in my Grandfather's toolbox. Awesome tool for pre-battery operated drivers/drills.
Thanx!
Man of many hats
wrangler is offline   Reply With Quote
Old 02-26-2009, 08:57 AM   #8
Thanks for all the input! I can see what they're used for but I'm still having trouble picturing why they're better than a straight shaft. Maybe I should just buy one and find out.
Old 02-26-2009, 09:18 AM   #9
the Musigician
LOTS easier on the wrists!!! it's a crank.... no twisting necessary.
i too have those 'yankees' shown above in my shed.... i guess that dates ME, huh? roflmao
DM
Old 02-26-2009, 09:25 AM   #10
Learning by Doing
Leah Frances's Avatar
I'll date myself too. I've never seen one of them before (is it a torture device?). But, I do have a small battery powered screw driver to save my wrists during installations. Maybe this just proves I'm a girl.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-26-2009, 09:47 AM   #11
Registered User
Termite's Avatar
Try one PirateKatz, you'll love it.
Old 02-26-2009, 10:14 AM   #12
I think I can picture it now. I'm going to buy one and try it out (I have a certain obsession with buying tools anyways).
On the subject of making things easier on the hands/wrists... Are there any tools to aid in twisting wire nuts? I spent the weekend changing fluorescent ballasts, adding junction boxes, and just cleaning up some really bad wiring in the addition to my house (I had no idea how much of a mess it was, since I always assumed it was properly done because they pulled a permit back in the 70's).
And my hands were absolutely killing me afterwards. Are there any kind of socket adapters meant for wire nuts? I don't know how an electrician can possibly wire an entire house and not be in agony and/or suffer from early onset arthritis.
Old 02-26-2009, 10:25 AM   #13
the Musigician
find an old socket (nut-driver even better) a bit larger than the wirenuts to be used. roll a piece of duct tape around the opening for cushioning. use drill or cordless screwdriver on slow speed. problem solved.
DM
Old 02-26-2009, 11:42 AM   #14
Registered User
Termite's Avatar
Wago Wal-Nuts are a good alternative for traditional wire nuts, especially for folks with sore fingers! They're a bit more expensive though.
Old 02-26-2009, 11:51 AM   #15
Rewards Points: 316
Yes, you are right. The picture is the yankee. It's been a long time my friend.
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 07:02 PM
Tub Drain Removal Tool rjordan392 Plumbing 6 07-08-2008 12:39 PM
Tool question jerryh3 Electrical 2 05-10-2008 09:17 PM
total air tool beginner question (real e-z) amakarevic Building & Construction 4 12-30-2007 09:56 PM
