Toggle Switch To Decora Plate Adapter? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 3 Post By chandler48
  • 1 Post By chandler48
  • 2 Post By Nealtw
  • 1 Post By l008com
Old 02-25-2019, 04:36 AM   #1
l008com's Avatar
Rewards Points: 672
Send a message via AIM to l008com
Question
Toggle Switch to Decora Plate Adapter?
I'm sure I've seen adapters for this in use before but I can't seem to find them anywhere. I know the simply solution is to just use a big fat decora switch where the toggle is. But I like the idea that every toggle switch in my house is for lights, and other stuff has non toggle switches, like the heat lamp and the timer switch, or the exhaust fan and the big rocker switch.
Anyway, a little plastic insert will solve this problem, someone must make them right?
l008com is offline   Reply With Quote
Old 02-25-2019, 04:46 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 2,958
Re: Toggle Switch to Decora Plate Adapter?
Why? A decora switch will look better, perform the same, and will fit the cover plate without having to modify it.
mpoulton, brric and RockyMtBeerMan like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 02-25-2019, 04:48 AM   #3
l008com's Avatar
Rewards Points: 672
Originally Posted by l008com View Post
...I know the simply solution is to just use a big fat decora switch where the toggle is. But I like the idea that every toggle switch in my house is for lights, and other stuff has non toggle switches, like the heat lamp and the timer switch, or the exhaust fan and the big rocker switch
Old 02-25-2019, 05:05 AM   #4
Mystriss's Avatar
Rewards Points: 6,712
I think you have to get this - https://www.amazon.com/Leviton-80414...ateway&sr=8-2v then cut out the slot for the toggle.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 02-25-2019, 05:10 AM   #5
Naildriver
chandler48's Avatar
OK buy this https://www.kyleswitchplates.com/1-t...-plates-ivory/
Just cost more than a decora switch.
lenaitch likes this.
Larry......
Old 02-25-2019, 05:12 AM   #6
Licensed electrician
Rewards Points: 3,766
Plates are already made with toggle and decora openings on the same plate.
Old 02-25-2019, 05:22 AM   #7
retired framer
Rewards Points: 12,918
https://www.kyleswitchplates.com/swi...blank-fillers/
lenaitch and l008com like this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 02-25-2019, 05:44 AM   #8
l008com's Avatar
Rewards Points: 672
Originally Posted by Nealtw View Post
Thanks! I was not finding that on google!
https://www.kyleswitchplates.com/dec...s-seymour-327/
They also have the decora to 3 keystone insert I was also having trouble finding. That's everything I need right now!
Nealtw likes this.
Multi Switch Loop? Arch50 Electrical 16 01-21-2018 02:23 PM
Warm light switch - Leviton Decora Smart Leoik Electrical 2 08-01-2017 11:35 PM
Can I use a Generator Transfer Switch to toggle power between 2 outdoor appliances? Pacifican Electrical 4 04-21-2015 06:25 PM
There is no two gang mud ring & wall plate for a CENTERED switch? miamicuse Electrical 4 06-07-2012 05:34 PM
Connecting Decora Switch cprao Electrical 9 03-30-2010 11:59 AM
