Three Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2010, 08:08 AM   #1
three way switch
Recently while doing carpentry in an older home (50 years), I came across a wiring scenario that puzzles me and I hope someone can enlighten me. The three bedrooms in this home all have a three way wall switch and no ceiling light. Power comes into the switch and a three wire apparently is fed to the six duplex devices in each room. My assumption was that this switch would activate the duplex devices or liven half the device. The problem is that the switch is live, both the top and bottom of the duplex is live regardless of the position of the switch and the brass tab on the duplex devices have not been removed. So the question is, why doesn't the circuit breaker trip and why would anyone wire a house where the switch is live but not liven a dplex device so the homeower MUST walk into a dark room and find the switch on a floor or table lamp???
miterjoint is offline   Reply With Quote
Old 08-19-2010, 08:35 AM   #2
Licensed electrician
Rewards Points: 3,662
The breaker doesn't trip because there is no overload or short. The unbroken tabs are just over-riding the switch.
According to the NEC the bedrooms should have a switch controlled lighting outlet. Sounds like someone didn't follow the rules or didn't know any better.
You said the bedroom had 3 way switches. Does the bedroom have 2 entrances or is one near the door and the other near the bed?
Old 08-19-2010, 11:52 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 24,048
Most likely someone change the duplex receptacles (possibly to make them three prong)and did not know enough to break the tabs.
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
