Thermostat Woes - Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2009, 07:52 PM   #1
Thermostat woes - help!
I am replacing a White-Rodgers programmable thermostat with a Honeywell (RTH2310B). The issue is that the Rodgers has 8 terminals and the Honeywell has 5 terminals. How do I make the correct connections? Thanks!
Rodgers:
C Black Wire
L No wire
W2 White wire
E Brown wire
R Red wire
G Green wire
O Orange wire
Y Yellow wire
Honeywell:
Rh ?
Rc ?
W ?
Y ?
G ?
bdelozie is offline   Reply With Quote
Old 08-05-2009, 08:11 PM   #2
Electrical Contractor
kbsparky's Avatar
You are attempting to replace a heat-pump thermostat with a non-heat pump one.
They are not compatible.
Return the new one to the store, and ask for a heat-pump type.
-KB
Old 08-05-2009, 08:14 PM   #3
Simple enough. Thanks KB!
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 09:21 AM
ac/furnace runs whatever thermostat settign donbohn HVAC 1 06-20-2009 05:42 AM
