Thermostat Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 08:36 PM   #1
Thermostat Wires
I am trying to install a new thermostat, the colored wires are not labeled as they should be from the wall. I have a white, red, blue and yellow wire. I have a gas heating system and an A/C unit. Can anyone tell me which of the wires go to which of the following letters on the thermostat itself?
Wires:
White
BLue
Red
Yellow
Letters:
W
Y
G
Rh (filled with a wire with a red tab and connected to the Rc)
Rc
Gidget is offline   Reply With Quote
Old 06-01-2010, 09:10 PM   #2
From the T-stat:
White is for the HEATING circuit
Yellow is for the COOLING circuit
Red is 24 VAC power
Blue is the 24 VAC Common/Neutral/Return
Green is for the FAN circuit
Good rule of thumb is to connect the G to the RC (while removing the 'jumper' to RH) This way, the COOLING circuit CANNOT be energized without the FAN circuit being ON first. (R can go to RH without the 'jumper' to RC on it.)
ControlTech is offline   Reply With Quote
The Following User Says Thank You to ControlTech For This Useful Post:
Gidget (06-01-2010)
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
