Thermostat On Outside Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-26-2010, 01:25 PM   #1
Rewards Points: 133
Thermostat on outside wall?
In my small reno of an office space, the best spot I can find away from the heaters themselves is on the opposite wall, which is the outside wall, rather than the partition wall.
It is insulated with R20 6" deep batts.
Is the rule about Tstats on inside walls inviolable?
Hossenfeffer is offline   Reply With Quote
Old 04-26-2010, 04:07 PM   #2
Rewards Points: 320
I think the thought behind this is that the outside wall is likely to be cold and not give a true reading of the room's temperature. I would think that as long as the wall is properly insulated and you seal the wire penetrations against drafts then it will be okay.
teamo is offline   Reply With Quote
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 10:30 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
building a wall against an exterior wall Mike L General DIY Discussions 2 08-20-2009 02:50 PM
Humm from box (transformer?) on wall near thermostat Crackers Electrical 8 08-06-2009 04:17 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
