Thermostat Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 12:13 PM   #1
thermostat installation
Hello, mt name is Tony. I really need some expert advice! My electricity had gotten disconnected awhile back, well when i got it reactivated my furnace nor central air unit would not work. I had someone come look at it a couple weeks ago, he told me he thought it was the thermostat. So I went to Lowes and picked up Hunter model#44860, (i guess thats what i needed because i have a heat pump). I installed it myself and I'm not sure if I have it right because I still have no heat. Ther wires from the wall were not labled and i have them as follows: Red to Rh, Yellow to Y1, Blue to Y2,White to W1, Black to W2, Brown to C,and Orange to O. Maybe i have them connected wrong? Maybe there is a problem somewhere else? Please give me your advice! I have 2 children and its only 10 degrees outside. Thank you so much! My e-mail is [email protected]
striktegis is offline   Reply With Quote
Old 12-06-2010, 07:13 PM   #2
Rewards Points: 2,398
You need to match the wires from the outside unit to the thermostat; colors aren't always followed correctly. Find out which terminals the wires go to outside and then match them up inside to the right terminals as per owner's manual.
bob22 is offline   Reply With Quote
Old 12-07-2010, 04:12 AM   #3
Rewards Points: 1,192
Call the Man,Aunt Bea!
bobelectric is offline   Reply With Quote
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
2 boilers thermostat wire installation... Handyman4u2fix HVAC 1 02-04-2010 12:50 AM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 09:56 AM
Trane Z Wave Thermostat Installation TommyTelephone HVAC 1 09-13-2009 03:51 AM
Thermostat Installation help helpless handyman HVAC 16 11-21-2006 08:31 PM
