Terminating An Unused Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2010, 12:10 AM   #1
Terminating an unused cable
I will be running new romex for a kitchen remodel. The existing cable is difficult to pull out, so I have to leave it in the wall. It will be disconnected at the panel and will not be live. Is there a requirement to terminate it somehow, or mark it as unused, or can I just leave it hanging there?
acerunner is offline   Reply With Quote
Old 03-24-2010, 06:25 AM   #2
Remodeling Contractor
connect the white (neutral) to the black (hot) so that if anyone attempts to reconnect it at the panel it will trip the circuit and not leave a live wire open in the wall. Otherwise you should be fine.
Old 03-24-2010, 06:41 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 960
DO NOT connect the wires like Bob stated!
If the wires are never to be used again, cut them off as high as you can in the wall, and remove the wires from the panel.
If there is a chance that you may need the wires again, then install the wires inside a box.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 03-24-2010, 07:56 AM   #4
Electrician
Rewards Points: 910
Mike Holmes on Holmes on Homes says to do this as well and I cringe whenever he says that. Like jbfan said do not do this, what happens if for some reason your breaker does not trip when turned back on.
darren is offline   Reply With Quote
Old 03-24-2010, 08:00 AM   #5
Rewards Points: 2,800
If the cable is so deteriorated that it cannot be used again, then cut off the end at the panel as far as you can but at least so it will no longer reach the panel. Then you can cut off the other end as far as you can.
A cable that can be re-used in the future is best left uncut. It should be removed from the panel and that end labeled as to where the other end is since the other end might be buried in a wall.
I would say it is okay to connect black and white together only at the end just outside the panel. As if to start a fad that the cable is decommissioned and the other end is not in an accessible box.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 03-24-2010, 10:11 AM   #6
Cap the ends, tag them at the panel and at the end point, and cut them as high up as you can.
clb2010 is offline   Reply With Quote
Old 03-24-2010, 05:32 PM   #7
Rewards Points: 252
I wouldn't want to do that with my (soon to be replaced) Federal Pacific panel!
Itsdanf is offline   Reply With Quote
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 04:31 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 11:00 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
