Terminating Conduit In Access Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2019, 12:47 AM   #1
Terminating conduit in access panel
I have a security access panel in a closet. Behind the wall is an attic. Through a 1.5in conduit, I have about 3 CAT5e cables running through from the attic through the access panel. Is there a way to seal or terminate the conduit? Right now I just have some masking tape around it, but would like to properly close it or reduce the air gap. I plan to run 2 more wires down the road so I don't want to permanently close it. Thought about duct seal, but ideal if there is a more flexible solution to open and close the conduit.
Kcrew98 is offline   Reply With Quote
Old 07-18-2019, 05:06 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,770
Re: Terminating conduit in access panel
This stuff can be pulled out later.
https://www.homedepot.ca/product/gar...ugs/1000406595
123pugsy is offline   Reply With Quote
Tags
access panel , conduit , terminate
