Temporary Power During Sub Panel Install - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-09-2009, 12:42 PM   #31
DIYer
You are assuming that the ground doesn't carry any current under no-fault, this is not strictly true. Every switching power supply leaks some to ground through its EMI filter. It's usually less than 1ma but it still happens. I have seen this float a disconnected ground up to 60 volts before from a single power supply, enough to feel a tingle. If you have a few switching power supplies, it all adds up.
I wouldn't want to be a plumber who disconnected a pipe fitting and then got hit with a few ma of current. Would be a nasty surprise, especially if you are holding something covered in molten solder at the time.
Gigs is offline   Reply With Quote
100A Fuse Panel Replacement Charlie1101 Electrical 4 07-25-2009 02:22 PM
How to install sub panel in detached garage 70' away MEC Electrical 5 02-09-2009 05:31 PM
Jumping from main panel to sub-panel teamjnz Electrical 23 09-25-2008 09:58 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Temporary power... MLO Electrical 8 02-18-2007 11:43 PM
