Telephone And Power Line - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 10:36 AM   #1
telephone and power line
What are options about running a phone line in the same trench (or conduit) as feeder line to outbuilding?
what can I do to protect or minimize interference?
MeanGene is offline   Reply With Quote
Old 07-14-2010, 10:46 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
metal conduit or maintaining as much distance between the two lines as possible. At least a foot separation but more if at all possible
The Following User Says Thank You to nap For This Useful Post:
MeanGene (07-14-2010)
Old 07-14-2010, 01:18 PM   #3
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
In addition to this, there is shielded cabled available at least for networking, and networking cable can be used for phones. Not positive if any of it is direct burial rated.
Jamie
jamiedolan is offline   Reply With Quote
Old 07-14-2010, 01:25 PM   #4
Handyman
Rewards Points: 520
Jamie is right, you can get shielded cable but it has to be in conduit. You can buy shielded u/g cable but expensive.
canadaclub is offline   Reply With Quote
Old 07-14-2010, 01:33 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 23,982
Phone can't be in the same conduit as power unless the phone wire has the same insulation ratings as the power cables. If you have phone cables with a 300 volt rating then it could be in the same conduit. It is virtually never done that however.
Old 07-14-2010, 02:27 PM   #6
Twisting both lines one or two turns/foot will reduce 60 Hz on your phone but that may be practical only for the phone line. It's called a twisted pair.
Nonmagnetic shield foil or braid is only good against E [electric] field interference.
In this case the interference is caused by the H [magnetic] field. Thick steel/iron is more costly and more effective for this type of shielding. For problem applications they use mu metal.
Old 07-14-2010, 03:35 PM   #7
Handyman
Rewards Points: 520
on the bright side, you can buy a wireless phone system from WallMart for less than $ 40, then no need to bury any wire
Old 07-14-2010, 07:26 PM   #8
Yes, the radiated energy is not so high that you can expect brain cancer or eyeball cancer, in the near future.
New telephone line humberguy Electrical 14 03-26-2010 12:59 PM
telephone grounding handifoot Electrical 3 06-19-2008 11:05 AM
