Taking A 220 Run And Installing A Sub Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-10-2010, 06:50 PM   #16
also.. is there anything special I have to do with the routing of the wiring? I keep reading different things..
If you are going across all of the ceiling joists, do you create little channels on top of each one for the wire to sit in? Or do you drill into them?
It seems like so many opinions differ on this.. I know you can't drill into the actual supports for the roof, but what about the ceiling?
ibjames is offline   Reply With Quote
Old 09-10-2010, 07:09 PM   #17
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the cable can be run on top of the joist but if it is near an access hatch (can't remember the specific distance offhand) you must install running boards on each side of the cable to prevent it from being walked on.
Old 09-11-2010, 12:42 AM   #18
" Euro " electrician
frenchelectrican's Avatar
2 meters* from the scuttle hole that where you will run into.
Merci.
Marc
* the same about 6 feet as well.
The Following User Says Thank You to frenchelectrican For This Useful Post:
nap (09-11-2010)
Old 09-20-2010, 05:19 PM   #19
so.. what size wire would I need to run 60A service?
Old 09-20-2010, 08:16 PM   #20
Normally with THHN/THWN conductors you can use 16mm { #6 AWG } in the conduit however there is one nice gotcha .,,,,,
If you use the NM or SER cable you will have to bump up to 25mm { # 4 AWG } due it have 60C rating while the THHN/THWN conductors are rated at 75 so it will make the diffrence.
Merci.
Marc
Old 09-21-2010, 10:58 AM   #21
Thanks a lot french, since this is getting run through the attic, I wasn't going to use conduit, do I need to?
also, what part of WI do you stay sometimes?
Old 09-21-2010, 09:03 PM   #22
Near Appleton Wisconsin
If you have open end you can able use the cable otherwise the conduit will work very nice due you don't have to make any splices or changes.
Merci,
Marc
Old 09-22-2010, 11:53 AM   #23
Nice, I grew up in Milwaukee Moved to San Diego 5 years ago
Old 09-22-2010, 04:27 PM   #24
sheesh, 20 posts to send pm, french, you have pm
The Following User Says Thank You to ibjames For This Useful Post:
frenchelectrican (09-22-2010)
Old 09-22-2010, 09:27 PM   #25
Ok got it and send ya a PM to ya.
Merci.
Marc
