Switching Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2018, 04:15 PM   #1
Rewards Points: 8
Switching light switch
Hi,
I'd like to replace a fan/light switch in my house. The current switch is one unit with two switches controlling either on/off for the fan/light independently. The replacement switch is one unit that has two multi-setting swtiches for each the fan/light.
Current switch is wired three black and a ground. The replacement switch has a ground (green) and then three others (red/black/blue).
Are these two switches compatible or will I not be able to replace the old switch with the new one?
Thank you!
A_Balt is offline   Reply With Quote
Old 07-08-2018, 04:47 PM   #2
retired framer
Rewards Points: 13,092
Re: Switching light switch
The single black on the other side of the old switch goes to black.
The light goes to blue and the fan goes to red
and ground goes to green.
Old 07-08-2018, 05:04 PM   #3
Guapo
Rewards Points: 11,950
It looks like it will work but you might not need to use all 4 positions on the new switch.
Guap0_ is offline   Reply With Quote
Tags
fan , light , switch
Troubleshoot a 4-way switch circuit: instructions for a 2-year-old pete0403 Electrical 22 09-28-2019 09:54 PM
Need to add 2nd switch and 2nd light to room: Can this light be wired as 2nd light? HTFreak Electrical 1 12-06-2016 04:04 PM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
