Switching From Electric To Gas Cooktop - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2019, 12:00 PM   #1
Rewards Points: 1,280
Switching from electric to gas cooktop
Hello
I'm thinking to switch from electric (induction) cooktop to gas
I will hire a licensed plumber for the gas stubout
For the electric, I have a junction box where the current cooktop's cable goes into, and connection is done thru screw terminal
Can I convert that 220V box into a 110V outlet by:
-) remove the 30 or 40 double pole circuit breaker and install 1 x 15A single pole circuit breaker (and then leave 1 panel slot open)
2) Keep the current cable as it is (will have to cap off the red wire in the panel and in the box)
3) install a standard 110V / 15A outlet using the black cable?
french_guy is offline   Reply With Quote
Old 12-03-2019, 01:00 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 228
Re: Switching from electric to gas cooktop
Yes you can. Likely the existing cable is too big to fit in the breaker or receptacle
Pigtail a #14 to the larger wire.
Sent from my Moto E (4) Plus using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 12-05-2019, 03:55 AM   #3
Mystriss's Avatar
Rewards Points: 4,930
Originally Posted by french_guy View Post
Hello
May I inquire why you're swapping from induction to gas? I've been waffling between the two since my glass top range is getting old, but I can't decide which I want to upgrade to.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 12-05-2019, 05:47 AM   #4
Licensed electrician
Rewards Points: 3,720
Install a filler blank in the opening next to the single pole breaker.
